Question about Sunbeam Humidifiers
Wont run in unit lift out and lift level control works fine put it back in unit [ very tight fit] lift level control wont work
Posted by rfe4956553 on
Oloyede Monsuru
    Genius:
  • 1,417 Answers
Hello.
The GE humidifier adds a continuous stream of cool mist intothe air, giving moisture to dry air due to cold weather or dry climate or tohelp those who desire additional moisture because of respiratory problems orallergies. Sold online and in many department or home retail stores, thehumidifier requires regular cleaning and maintenance for proper functioning andto help keep mineral scale or bacteria from growing in the humidifier. ·1 Connect the power cord on the GE humidifier firmly to a power outlet if thehumidifier is not working. Replace or reset the circuit breaker as necessary.Turn the power switch to "On" if there is power but the unit is notoperating. · 2 Fill thewater tank to the "Fill" mark if the mist output is low or notpresent. Wait 15 minutes after filling the tank and before starting thehumidifier to allow the wick filter to absorb the water for proper function.Turn the humidistat knob to a higher setting for higher output. · 3 Check the capon the water tank and close the cap firmly. Check the rubber tank cap ring onthe cap and reseat firmly to help provide a better seal. · 4 Replace thewick filter with a new wick filter, available through General Electric, if thewick filter inside the base turns brown. Replacement parts may be ordered bycalling 877-207-0923. · 5 Clean thewater tank with vinegar and a soft brush if the water begins to get cloudy.Rinse well before refilling with water. Use cold water in the tank, as warm orhot water may make the water appear cloudy. · 6 Loosen thetank cap slightly if the humidifier cycles on and off unexpectedly. Turn theknob to a higher or lower setting. Thanks.
Posted on Sep 09, 2011
I hear no water draining from my heathy soluions lennox humidifier just put in a new filter
None leaking? Try removing the cover, and manually cycling on the controler switch? Does the solenoid click on, next to the humidifier (the unit with the water line running through it, with wires coming out of it)? If it does click on, is water running down the water pad? It doesn't necessarily drain water when it's working correctly. All of the water SHOULD be getting evaporated into the air return duct.
If it's clicking on, but no water is running out, you should check the water supply saddle valve and make sure it wasn't turned off during servicing.
If it's not clicking on, you should test that you are getting voltage (12v-18v DC) to the solenoid. If you're not, check all wiring connections and make sure they're tight. If you still don't get power, you have either a problem with your control unit/humidistat, your DC power supply, or the control board on your furnace.
Jan 06, 2013 | Humidifiers
Honeywell humidifier mod. HE-255, NOT WORKING
If it's not clicking on, you should test that you are getting voltage (12v-18v DC) to the solenoid. If you're not, check all wiring connections and make sure they're tight. If you still don't get power, you have either a problem with your control unit/humidistat, your DC power supply, or the control board on your furnace. You may need to call a HVAC technician at that point, depending on your comfort level/skill level in that regard.
No water going to evaporater plate
Try removing the cover, and manually cycling on the controler switch? Does the solenoid click on, next to the humidifier (the unit with the water line running through it, with wires coming out of it)? If it does click on, is water running down the water pad? It doesn't necessarily drain water out of the unit when it's working correctly. All of the water SHOULD be getting evaporated into the air return duct.
Honeywell he220 humidifier problems
When you say the solenoid "stays hot" do you mean it's physically hot to the touch? Hotter than the water lines running into it?
If the solenoid is getting hot, it probably has a bad coil, and if you continue to operate it, you will probably burn up your DC power supply.
If you're getting voltage, you have water pressure, and the solenoid is still not opening, replace the solenoid.
Jan 05, 2013 | Honeywell HE220A1019 Whole House...
I have an HM 495, the past 4 days it has been working fine. Now there is no mist coming out and it seems to be spilling water out of the back of the base. What is the problem? I have not been using warm or...
When this happened to me, I took the tank into the bathroom to look at the bottom and then I tried to turn the knob and it wasn't all the way tight. After I tightened it, I put it back on the base and the mist started right away.
Jan 14, 2011 | Holmes Products HM495-UC Humidifier
Kenmore Humidifier 14114 - the fan suddenly stopped running. Changed fliter and water, unplugged the unit, changed dial to highest humidity level - the unit will not run.
Hi
Please turn off the power to the unit and unplug it. Now check the fuse inside the unit, make sure its fine and not burnt If fuse seems OK then inspect the connections to the fan and make sure the wires are not cut. Also, inspect the control for any burnt components, use a multimeter to confirm. Hope this helps... Please post back with complete model# if you need more information.
Daniel
Jan 04, 2011 | Kenmore Humidifiers
Hi, We have a new house fitted with a Honeywell HE225 humidifier. It does not seem to work. Doesn't matter what we set it to, there is still way too much condensation on all the windows. We ended up...
Cut the power to the whole house humidifier and turn off the water pipe to it. If you want it running in the winter, put the water back on, but put a timer or a humidistat on the power cable to only allow it to run a certain amount of time per day, or to only run it the humidistat shows an RH lower than 45 percent (or whatever your comfort level is).
May 27, 2017 | Honeywell HE225B Humidifier
My 1042 Power Humidifier has water under the PVC pipe leading from the unit into the drain. Does that mean the unit itself is leaking water?
Hi, if the unit is leaking and it looks as though it is coming from the PVC pipe, more then likely its leaking at the unit its self where the pipe connects. Water will run down the pipe and drip down line. Dry it off and put your hand around where the PVC pipe screws into unit. Unless the pipe is cracked, this is where the leak is. If the fitting is a male or female threaded PVC fitting and a piece of PVC pipe that goes to the drain, you can repair this very easy. Just cut the pipe near the fitting with a hacksaw. Unscrew the fitting that goes to unit. Go to a hardware store like Home Depot, take the old fitting with you and buy a replacement. Buy a coupling, a small can of clear PVC glue and a small can or tube of pipe dope to put on the fitting threads. Screw the fitting in first and make sure it has pipe dope on it, get it tight with pliers. Take the pipe and coupling and glue it on the pipe. Put glue on the other end and slide it in the fitting that was where it was leaking before. Hold it in place for a few seconds. Once you put the glue on, be ready to put it together as it drys super fast and you cant take it apart once it sets. Very easy to repair and the parts cost pennys. Keep me posted. You can do this and will learn about plumbing! Good Luck.
Shastalaker7
Jan 24, 2010 | General Filters 1042-LH Humidifier
Honeywell 6013i new machine will light up but will not work
Unplug the unit (safety first), remove the two water jugs at the back lay them down. Find a tray large enough to fit the motor and filter inside of it put it next to the unit. Lift off the motor and set it next to the tray, lift out the filter and set it into the tray (in might be wet, and we wouldn't want a mess). Look for a small plastic tower in the base, inside that tower is supposed to be a float with a screw threaded into the top. If there is no screw, grab a small one that is about 5/8" long and screw it in about 1/4" put the filter and motor on, verify that the motor is sitting evenly on the base. If it isn't, turn the screw colckwise 1 full turn and recheck the motor/base fit. When it looks even, put the motor back on, plug it in and hope for the best!!
Take your time and don't forget that this is not a precision machine, so some 'adjustments' are necessary
Nov 24, 2008 | Honeywell QuietCare HCM-6013i Humidifier
Kenmore 14-gallon humidifier--only right bottle will drain
I just read the reviews because I am considering buying it, and many owners complained of the same problem. Many people said they tried to fix the problems by leveling the machine, however, one guy said he figured it out: just level the machine slightly toward the REAR and it drains correctly. Try it. I hope he's right, because I'm going to take a chance on this machine and it better work well!!! :)
Mar 27, 2008 | Humidifiers
Humidifiers Logo
453 people viewed this question
Top Sunbeam Humidifiers Experts
Marvin
Marvin
boogiecheck
Level 1 Expert
Muntejaya Ginting
Muntejaya Ginting
Are you a Sunbeam Humidifier Expert? Answer questions, earn points and help others
