"E20" is indicates a drain problem.
- Set towels under the hoses in the rear of the washer and disconnect the drain hose. Clean the drain hose screen and look for debris where the hose connects to the washer. Clean as necessary.
- Remove the front access panel from the washing machine and locate the drain pump. Remove the screw clamp and clean out any debris that may be causing an obstruction.
- Clean the sump hose that is connected to the trap cup and reassemble. Close the front access panel.
- Restore power and press "Drain/Spin" to remove any remaining water from the tub.
Hope helps (remember to rate this answer).
Testimonial: "Thanks for the info, will try and let you know"
how do you get front panel off
My model is an ATF6000FS and there is no front access panel that I can tell. Any suggestions? Thanks!
If you were looking for a way to earn some extra income every week... Look no more!!!! Here is a great opportunity for everyone to make $95/per hour by working in your free time on your computer from home... I've been doing this for 6 months now and last month i've earned my first five-figure paycheck ever!!!! Learn more about it on the following link..........www.smartcash1.com
