Question about Troy Garden
I have a 2 cycle Troy-Bilt line trimmer. I've had
Posted by RAY BRENEMAN on
Roy Cagle
    President:
  • Troy Master
  • 1,545 Answers
Sometimes, unfortunately, the chemicals and solvents used in a "dip" and/or cleaning solution are too harsh. They tend to "swell" the very sensitive check valves inside the carb. The idle fuel circuit has one, the high speed main nozzle has one, and there are one or two inside the primer pase assembly on top of the carb. You state that it won't idle, but does it run otherwise. If it does, some carb adjustments may be required on the L and H screws to get it to idle.
Posted on Sep 09, 2011
  • Roy Cagle
    Roy Cagle Sep 09, 2011
    Always only use WD-40 and low pressure air to clean this small sensitive carburetors. Strong solvent cleaners and high PSI air can and will damage the check valves in them, causing idle and running problems.
  • Roy Cagle
    Roy Cagle Sep 10, 2011
    It is quite possible that your carburetor is now in need of the periodic replacement of the gasket and diaphragms inside it. ALL these carbs require this at some point. A (G & D kit) they are called; is relatively inexpensive and will restore ALL functionality to the carb is it hasn't been damaged by strong solvents or high pressure air.
I have a Troy-Bilt XP grass trimmer...only run on full choke, I replaced the fuel filter because there was plugged.Still no help. I ordered a new carb and replaced it and still had the same problem.
When you installed the new carb did you adjust it for your engine? Idle control, idle mixture, fast misture? Running only with choke indicates that engine is not getting enough gas routinely via the main jet.
Sep 22, 2017 | Troy-Bilt Garden
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt edger dies as soon as its under a load--like edging my driveway.
The only real explanation for this is that a tiny piece of dirt has gotten into one of the tiny fuel jets. Remove the carb and blow it out thoroughly with compressed air.
Nov 23, 2011 | Mtd Garden
I have a 2 cycle Troy-Bilt TB90BC line trimmer. Won't idle. I've had the carburetor dipped, installed a new carb kit, replace the gas lines, but will only run at full speeds. Dies out easily....
One of three things is occuring here. The IDLE SPEED SCREW (Phillips head) on the throttle plate is screwed in way too far. The L and H mixture screws are open way too much allowing the carb to use excessive fuel, even on startup. Those 2 screws may need adjusting. The metering lever in your carb is not adjusted flush with the carb body flange and is holding the gas needle open constantly. Check these things and post back.
Sep 09, 2011 | Troy Garden
I have a troy bilt 4 cycle. I have had it for
clean the carburetor. and make sure the screen in the carburetor is clean and clear. your best to take it out and spray a drop of carb clean and burn it off. also make sure the fuel filter is clean to. the diaphrams may be a little stiff so clean them to.
May 02, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Ive got a troy-bilt gas trimmer tb25cs it has always ran perfect,until now when i start it up aqnd give it gas it stops running and leaks gas
Check and clean your spark arrestor located behind a diverter plate on outside of muffler. You'll need a #25 Torx, or one slot screwdriver and wrench to take the plate off. Clean it with carb cleaner and wire brush and re-install. If this screen gets clogged, it could lead to fuel spray coming out of carb throat. Clean and re-oil the sponge filter while you're at it. Hope it helps!
Mar 24, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Starts and then shut off Troy bilt edger
clean out carb and run gas cleaner throught the tank
Dec 27, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy-Bilt TB425CS trimmer hard to start, won't accelerate
Hi the key is moulded as part of the flywheel on most machines these days which doesent take much to sheer off , By the sounds of it this may well be your problem.
Sep 08, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Troy Bilt in Hell String Trimmer TB465SS Running Problem
You need to clean the carb. or you may need to buy a carb. kit. But do a cleaning on it first. If you need tips on how to best do this, just let me know. Also check the fuel lines for cracks. As they age, they become brittle.
Jim
May 31, 2009 | Troy -Bilt String Trimmer/Blower...
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
309 people viewed this question
Top Troy Garden Experts
colesmowers
Brian Anderson
Dennis Key
Dennis Key
Are you a Troy Garden Expert? Answer questions, earn points and help others
