Question about Texas Instruments TI-30XA Calculator
Hi, how do i calculate log^-1 on my ti-30xa? for example, in order to calculate log^-1(-2), what do i do? thank you.
Posted by asmarah_a on
k24674
  • Texas Instru... Master
  • 8,091 Answers
The inverse of the common log function is the power function with base 10 (10^). It shares the same physical key as the log. You acees the function by pressing [2nd] [log]
Posted on Oct 15, 2011
Hi, how do i calculate log^-1(-2) on my ti-30xa? thank u.
The inverse of the log function is the power function.
For log in base 10 that inverse is 10 to a power of
More generally, let b be the base of the logarithm. If y=log_b (x) then x=b^y
For your case log=log_10, to calculate the inverse you perform 10^(-2)=0.01=1/100
On calculators the log in base 10 and its inverse share the same physical key. One is accessed directly, the other is the shifted key function.
Sep 09, 2011 | Texas Instruments TI-30XA Calculator
How do you find the log of 9.01 using TI 30xA calculator?
To calculate the common (base 10) log of 9.01, press 9 . 0 1 LOG =
To calculate the natural (base 3) log of 9.01, press 9 . 0 1 LN =
Both the LOG and LN keys are on the top row of the keyboard.
May 09, 2011 | Texas Instruments TI-30XA Calculator
I want to know how to enter basic logs into the calculator: Example. Log3^9=2 How can you enter this into the calculator?
The 30XA only has logarithm functions for base e and base 10. However, you can calculate the logarithm to any base by using the relationship logb x = log x / log b = ln x / ln b
To calculate log3 of 9, press
9 LOG / 3 LOG =
or
9 LN / 3 LN =
Apr 03, 2011 | Texas Instruments TI-30XA Calculator
How do I convert from decimals to fraction with my TI-30X IIS calculator? I need the step by step process
The following examples will demonstrate how to convert decimals into fractions using the TI-30Xa and TI-30Xa Solar. Please be aware that TI-30Xa Solar School Edition calculators do not have this functionality.
Example: Convert .25 to 1/4
- Input .25, press [2nd][<--] (says F<>D above it).
** F<>D means fraction to decimal, decimal to fraction.
Example: Convert 1.38 to 1_19/50
- Input 1.38, press [2nd][<--].
Example: Convert 9.75 to 9_3/4
- Input 9.75, press [2nd]{<--].
Mar 08, 2011 | Texas Instruments TI-30XA Calculator
Can i do sigma notation on a ti-30xa calculator?
No. There are some keys on the TI-30XA that may make you think so, but they are statistical operations. For example, you can enter values using the Sigma+ key and the TI-30XA can give you the sum of the values entered, sum of the squares, mean value, standard deviation and so on.
You cannot do calculations like "Give me the sum of all integers from 1 to 100" with the TI-30XA, you'd need a far more sophisticated calculator.
Jan 06, 2011 | Texas Instruments TI-30XA Calculator
I need to use a TI 30Xa to evaluate a Logarithm Log5 1/625 Not sure how to use the TI to do Log5
Use the relation log5(x) = log(x) / log(5) = ln(x) / ln(5)
LOG ( 1 / 625 ) / LOG 5 =
or
LN ( 1 / 625 ) / LN 5 =
Mar 11, 2010 | Texas Instruments TI-30XA Calculator
How do i find the negative log on a TI-30Xa
Ex: calculate -log(15.32)
  1. Calculate the log 15.32 [LOG] [=] result 1.185258765
  2. Then press the change sign key (-) result -1.185258765
You can also try 15.32 [LOG] (-) [=]. Try to veriufy it on your calculator.
Hope it helps
Dec 13, 2009 | Texas Instruments TI-30XA Calculator
Using the correct key combination to determine inverse log
Sorry to contradict you but there are many types of logarithms, the most important ones are
  1. the common logarithms (log in base 10),
  2. the natural logarithms (logarithms in base e)
  3. the binary logarithms (logarithms in base 2)
On calculators, the common logarithms are labeled [LOG], and the natural logarithms are labeled [LN].
The inverse function of the natural log function is the exponential (e^(x)), and the inverse of the log in base ten function is the function ten to the power of. It is called (sometimes) the antilog
Ex:
Question What is the antilog of 3.5678?
Answer The antilog of 3.5678 is 10^(3.5678) = 3696.579068
Verification: log(3696.57908) =3.5678
Hope it helps.
Nov 29, 2009 | Texas Instruments TI-30XA Calculator
Texas Instruments TI-30XA Calculator Logo
185 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
