Question about Stanley Professional Backpack Poly 4-Gallon Sprayer #61804
I need a new rubber seal for the plunger piston on my stanley backpack sprayer. Where can I get one of these? Is there a web site for ordering these parts?
Posted by twjohnson on
Mark T
  • 776 Answers
Drive out to the country side and look for a ACE or TrueValue hardware store. Bring your sprayer with you. They will likely have the right part for you in stock.
Posted on Sep 09, 2011
How do I open a stanley fatmax 5watt waterproof rechargeable spotlight without ruining the watertight seal ?????
It may not be possible if seal is stuck to either surface. Best just open it first. If seal breaks, then either replace the seal if one available or replace the unit
Dec 11, 2017 | Stanley 5 Watt Led Waterproof Rechargeable...
Stanley backpack sprayer top is stuck....... how do I get it off?
Hi Chris:
Seems a bit extreme to consider using the 12 gauge. I've found that a .22 works quite well. (Humour)
Hint! Pressurized tanks must have the pressure relieved BEFORE the lid can be removed.
If the lid has been over tightened or has stuck, you'll need to get more leverage to unscrew it. Sometimes a rag wrapped around it is all it takes.
You can also try pouring hot water over the cap. Lay the tank flat so the rim of the cap gets the heat. Wrap an old towel around it first so it gets a good hot soak.
Should come off without the artillery.
Cheers
Mar 19, 2016 | Stanley Professional Backpack Poly...
Is there someplace to buy a whole rubber washer repair/rebuild kit for a Roundup 4gal BP sprayer? It's square and was built in 2005 unlike the rounded newer ones. thx joe
I've found buying one thats too big and cutting it to size and shape works best on my sprayer. You could go for a sheet of rubber and cut it all out with an exacto knife too.
May 13, 2014 | Roundup Garden
Parts sprayer stanley
I would like the answer yo that question
May 10, 2013 | Stanley Professional Backpack Poly...
I have a Stanly backpack sprayer pro 61804n and need a repair manual. Were could I find one. Thank You, Chuck
The picture looks a lot like a Solo sprayer I have. I wouldn't be surprised if Solo made them for Stanley. Do a search for Solo sprayers. They have a site. My sprayer is a Solo 425
Jun 21, 2010 | Stanley Professional Backpack Poly...
MY STANLEY 61804 DOES NOT PUMP. THE PUMP HANDLE JUST POPS STRAIGHT DOWN EVERY TIME i TRY TO PUMP IT. ONLY USED 3 X. wHATS THE PROBLEM ???
the darker Seal has come off the plunger at the bottom of the unit , easy 5 min fix , just unscrew the allen keys at the bootonm take off the cover and remove the plunger , you'll see the plunger seal still inside you can fish it out with an allen key or similar tool clip it on again and reassemble
Oct 29, 2009 | Stanley Professional Backpack Poly...
Stanley Professional Backpack Poly 4-Gallon Sprayer #61804 Logo
1,593 people viewed this question
Top Stanley Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
mpservices
Are you a Stanley Garden Expert? Answer questions, earn points and help others
