Question about Coleman Powermate Powermate 5000W Generator
I have 5000 watt coleman generator 9 hp brigg n stration engine. i need to know what weigh or kind of oil to use? Thanks, Lee
Posted by dfl442 on
Charles Stewart
    New Friend:
  • 29 Answers
Depends on the temerature 40 and above SAE 30
0 to 40 SAE 5w-30 to 10w-30
Posted on Dec 12, 2011
I have a Coleman Pro-Gen 5000 with a Briggs and Stratton motor in it, I was wondering what kind of oil to use in it and what size sparkplugs I need
30W OIL, take old plug to store customer service will match. Parts: http://www.ereplacementparts.com/powermate-generator-parts-c-117046_130613.html?gclid=COe1kb_yi80CFZGJaQodXvYMXg Info: look on valve cover "DOHC" marked. On the side is the model number for the engine. Search on that model number for engine parts.
Jun 02, 2016 | Coleman Electrical Supplies
Power cord does not retract immediately
Coleman Powermate Generator 5000 Watts / 6250 Watts ...
? 3:27
https://www.youtube.com/watch?v=IROa5QfPqkU
Nov 8, 2012 - Uploaded by Carlos Roman
This 5000 watt generator is great for backup power at home or forpower ... Coleman Powermate Generator 5000 Watts / 6250 Watts ... This feature is not available right now. ... folding handle, 1 quart, of oil, and 25ft generator convenience cord. ... How to convert a generator recoil starter to an electric starter!
pull cord won t retract Power Generators Questions ... - Fixya
www.fixya.com > Forum > Tags > pull cord won t retract
Power Generators pull cord won t retract questions and answers. Ask your pull cordwon t ... Question about Powermate Powermate 5000W Generator. 2 Answers · I was running my coleman powermate 6250 gen power ... cord 6250 trips out ... The pullcord does not rewind onto the pulley when pulled. At first I thought it was ...
Best Portable Generator Reviews
Feb 03, 2016 | Coleman Powermate Powermate 5000W...
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
What weight oil do I use for a 5000 watt Coleman generator
Depends on the temperature where yuo will operate it, but a good multi-viscosity oil like 10W-30 should work. 5W-30 for cold climates.
Sep 07, 2014 | Coleman Powermate 5000 Portable Generator...
Coleman Powermate 7,000 Watt 13 Hp Portable Generator #PM049700 need to know what kind of oil to use and replacement sparkplug
we need to know the make of the motor....most use a SAE30 four stroke oil....not sure of the plug without knowing the make of motor.
Jul 23, 2010 | Coleman Powermate 7,000 Watt 13 Hp...
Can I install a avr (automatic voltage regulator) on my coleman 6250 (5000 watt continuous) gen set with a subaru engine. I know that some of the models come with the avr and some do not. mine did not have...
This is really not something you can do. There is a fair bit of engineering that would have to be done and then there is wiring and mounting, etc.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 10, 2009 | Coleman Powermate Powermate 5000W...
5000 watt generator no juice
most generators have a reset button. check your manual under the trouble shooter section good luck.
Jan 26, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Powermate 5000W Generator Logo
161 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
john h
Tim Venetis
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
