Vacuums Logo
Posted on Nov 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses complete power it will continue to run . but eventually it stalls out any way and will not restart with out jump starting.
NOEL
Level 3:
Top Expert:
  • Simplicity Master 8,606 Answers
  • Posted on Nov 30, 2017
NOEL
Simplicity Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2318959
Points
68630
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
4 Related Answers
Anonymous
  • 807 Answers
  • Posted on Mar 31, 2008
SOURCE: lawnmower
There may be a thermal fuse fitted to the motor, sometimes they reset when they cool down. Sometimes they are a one shot fuse, when they blow the have to be replaced.
There may also be a reset switch on or inside the operating lever/switch.
Have you also checked the operating switch/lever for a bad connection or a wire come loose.
Anonymous
  • 3917 Answers
  • Posted on May 24, 2011
SOURCE: MTD Yard Machine, 3.5HP /
Have you checked the primers on both of these units? It is possible that the primers are not putting enough fuel into the system. Look for holes or torn edges. Depending on the engine models. Also it can be lack of necessary vacuum and compression in the combustion chamber. But most probably it is a carb issue. It is suggested to rebuild the carburetor. Also when you clean the carburetor make sure the jet screws are seated in proper position in the way when you put the jets back in, you know to lightly seat them first and then turn them back out to their correct position before you started.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
askdyson
AskDyson
  • 2572 Answers
  • Posted on Sep 30, 2011
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson won't go down, stay upright. As I forced
    I'm sorry to hear you're having difficulties with your DC07. I'd advise against turning the cleaner on again, and encourage you to get in touch with us directly so we can help resolve this issue for you as quickly as possible.
    You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
    Kind regards,
    Jack
    Dyson Online Customer Support
    Anonymous
    • 31 Answers
    • Posted on Nov 20, 2011
    SOURCE: changed bag now motor won't start. The beater still works
    you may have debris in the area around the motor, or it may have something lodged in the motor.
    2answers
    2helpful
    My Electrolux Rapido wet&dry won't start. The battery is empty and the blue light flashes when I plug in the charger.
    this sounds totally silly but is the power button on the vacuum actually off? Had the same problem, where the battery was completely empty i didn't know my son had switched the vacuum on put it on charge and the light was flashing. I took it off the charging stand pressed the power button then put it back....now charging perfectly. Anyone who doesnt have this appliance will think you sound stupid but its just a clicky button so visually the button looks the same on or off.
    Battery is charged motor won't start
    I am sorry to hear you are having difficulty with your DC35. Based on the details you provided we would appreciate the opportunity to trouble shoot with you and we may be able to resolve this issue over the phone.
    At your earliest convenience, please call us directly at 1-866-693-9766 (US) or 0800 298 0298 (UK). We look forward to speaking with you.
    Best wishes,
    Jessica
    Replacement of v belt
    Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
    2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
    3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
    4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
    5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
    6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
    7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
    THanks
    Apr 02, 2012 • Vacuums
    Dco7 won't start
    I'm sorry to hear you're having difficulties with your DC07. If the machine won't start at all, I'd encourage you to call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can run through some troubleshooting with you to help resolve this. We'll look forward to hearing from you - please have the machine to hand when you call.
    Best wishes,
    Jack
    http://www.dyson.com
    Changed bag now motor won't start. The beater still works
    Nov 20, 2011 • Vacuums
    Dyson vacuum cleaner was working ok but now is dead. nothing. I have changed the fuse for one I know is working.
    Sorry to hear you're having difficulties with your Dyson vacuum. If the cleaner won't start at all, it's probably best if you get in touch with us directly so one of our experts can run through some troubleshooting checks over the phone with you. You can call us free on 08002980298 - our Helpline is open from 7am until 10pm, 7 days a week. We'll look forward to hearing from you.
    Kind regards,
    Jack
    Fully charged, filters cleaned, vacuum keeps shutting down in and then starts again only to shut off again. the 6 minute time limit is not used up.
    Your battery is losing voltage too quick. It has probably developed a 'memory'. Dyson claims that their handheld has the best suction out of all the handhelds out there. In order to maintain that claim the circuit board will shut off power to the motor when the voltage drops below adequate charge for full suction.
    We need someone who can teach us to bypass that part of the circuit so it won't cut power to the motor or you need to get a new battery.
    Shorting the battery like an Aircraft battery then re-charging won't fix it.
    Lawnmower
    Mar 31, 2008 • Vacuums
    Top Simplicity Vacuums Experts
    NOEL
    NOEL
    john h
    Are you a Simplicity Vacuum Expert? Answer questions, earn points and help others
