Not sure about the "a" sub-model part....
http://www.retrevo.com/support/RCA-RV9900-Receivers-manual/id/19241ci053/t/2/
Page 10.
There's a strange requirement to press the '0' before presets '1', '2' or '3' but not for '4' through '30'. Go figure.
Testimonial: "Thanks!"
Where did you say you didn't have the remote? You'll need one for a lot more than radio presets.
A substitute is available.
http://remotes.com/remotes/servlet/rs?a=...
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press (PRESET).
The Preset screen is displayed.
3 Rotate the Double Action encoder to select the
preset number.
4 Press and hold /ENTER for at least 2 seconds.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
• A total of 18 stations can be stored in the preset memory (6 stations
for each band; FM1, FM2 and AM).
• If you store a station in a preset memory which already has a station,
the current station will be cleared and replaced with the new station.
• Press in the outer ring and rotate the Double Action encoder to the
left or right on the Preset screen, you can switch the Preset screen of
another band.
FM-1 FM-2 AM FM-1
You can also change the desired radio band by pressing BAND.
Hope this helps.
Zeppelinx12
Found the manual but not the remote. Was hoping to set stations on the reciver itself. Not sure how to get to the memory to do so.
