Question about Rival VS107 Seal A Meal Vacuum Food Sealer
Heat tape doesn't get hot on seal a meal vs107
Posted by bjsmile on
2 Related Answers
pdarrach
pdarrach
SOURCE: When I go to SEAL, it burns a small hole clear thru the bag. One little metal peice on the sealing strip has burned right thru the white heating strip, therefore, it isn't sealing completely.
You need new tape to replace the one presently covering the heat element. You can get a roll of it for just US$7.99. Look at the FixYa question "where [or how maybe] can I get a new tape." I think that you have to be sure that the heat element is flat. I bought a used unit with that problem and the element had somehow gotten bent. Ordered the tape this morning and the cost is worth the hopeful fix.
Posted on Oct 02, 2012
pdarrach
pdarrach
SOURCE: Seal-a-Meal seal has blister on it
I think that you have the same problem that I have. The protective tape over the heating element [a strip in my case] has a hole in it and allows the element to come in direct contact with the bag. Also, the heating strip had a kink in it was was no longer flat. I carefully cleaned the heating strip and flattened it out as best I can. I have ordered some tape from : http://www.ebay.com/itm/170848027703?item=170848027703&viewitem=&sspagename=ADME:X:AAQ:MOTORS:1123&vxp=mtr to replace the defective one. A simple job.
Posted on Oct 03, 2012
Do they make special bags for this unit
They do! You can get them on the Seal-A-Meal website or even on Amazon. Here's a link.
Vacuum Sealers Accessories
Nov 20, 2015 | Rival VS107 Seal A Meal Vacuum Food Sealer
How does the top of the machine snap shut? Is it supposed to snap shut before sealing? How do I seal the bottom of the plastic sheets so that I can seal the rest of the plastic sheet?
You seal the bottom then pull out the length you need, insert food and vacuum and seal the top. In other words, the top of one bag becomes the bottom of the next one.
Feb 27, 2015 | Rival VS107 Seal-A-Meal Vacuum Food Sealer
Where can i get a new heat tape for my seal a meal
Crazy,, I've only used it three times and the heat seal already went out,,, will never buy this product again
Apr 29, 2014 | Rival VS230 Seal A Meal Vacuum Food Sealer
Jul 30, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Jul 17, 2012 | Rival VS230 Seal A Meal Vacuum Food Sealer
Seal-a-meal food storage system
You can buy the replacement part on KMart's website.
Jul 04, 2012 | Rival VS107 Seal A Meal Vacuum Food Sealer
Need upper and lower sealing gaskets for Rival Seal-A-Meal VS107
I've been told you can order replacement gaskets from Rival, about $6/set 1-800-557-4825 and $8 shipping, so may want to stock up (prices were quoted from 2012)
Sep 02, 2011 | Rival VS107 Seal A Meal Vacuum Food Sealer
Heat sealer does not heat
Sorry to read about your problem, I hope this helps you out.
after you try to seal, open the unit..feel the white heat tape..check to feel if hot, if not..you have a defective unit....
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 25, 2010 | Rival VS230 Seal A Meal Vacuum Food Sealer
Rival VS107 Seal A Meal Vacuum Food Sealer Logo
134 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
