Question about HP Compaq FS7600 17" CRT Monitor
How to change red blue and green color on monitor hp7540
Posted by lstetler on
Thomas Lee Miller
    Scholar:
    New Friend:
  • 118 Answers
Press the menu button on the monitor, should be the far left button...use the minus and plus buttons to scroll thru the menu. Select the function you want by pressing the far right button (not the power). The function you want is the one witht the temp icon and the letter "K". press the far right buttion again and use the the plus and minus buttons to adjust the level.
Hope that helps.
Tom Miller
Broadcast Engineering
Posted on Sep 08, 2011
I have an HP7540 monitor that I need to be able to change red, blue and green colors on thru the menu
I hope you know how to enter and navigate through the OSD (On-Screen Display) menu of your monitor.
Enter the menu and navigate to 'Color' menu.
Under that select 'User'.
Now you can select either Red, Green or Blue.
After selecting a color it can be increased or decreased.
Press Exit button to go back, select the next color and set it to your liking.
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
My screen is green i was going to change monters didn't work so i put it back and it turn green.help please.
Red, Green, and Blue are the colors sent from your computer to the monitor. Sounds like red and blue are not working. If you've tried a new monitor, I'd try a new video cable next. Then clean the connector on the back of the computer (compressed air). Finally, replace either the video card or the computer.
Oct 04, 2010 | Computers & Internet
Can't red and green colors
This usually means the red or green or both primary color module is bad. Monitors come with 3 primary color module controllers and they use them in various combinations to make the other colors. The primary colors are blue, green, and red.
Sep 17, 2010 | NEC AccuSync 900 19" CRT Monitor
MY MONITER CHANGES COLOR AND ITS PISSING ME OFF HOW CAN I DO IT. IT ALWAYS CHANGES COLOR MOST OF THE TIME IT CHANGES TO RED COLOR
One or two of your color guns are failing. On a CRT, there are three color guns, Red, Green, Blue. They work together to produce all colors in the spectrum. If the monitor goes all one color, it generally means at least one color gun is failing. The cost to repair far exceeds the value of the monitor or the price of a new LCD panel.
Mar 11, 2010 | HP Pavilion MX70 17" CRT Monitor
Monitor only displays blue color, no red or green
hi there, it may be that the RGB balance has been changed. Try getting a person that knows about monitors to calibrate the colors correctly. Or, connect the computer to a different monitor. If it still displays blue, it's a problem for a expert.
Jan 18, 2010 | ViewSonic E790 Monitor
Monitor turns green
This sounds like a problem with the cable. Monitors have Red, Green, and Blue signals. I have seen it where the cable has a short, or the plug has a bent or loose pin, and this causes the monitor to turn green.
It is also possible, but doubtful, that the video card is trying to run it as a Black and White monitor. B&W signal is sent over the green channel.
Jul 29, 2009 | Samsung SyncMaster 753S 17" CRT Monitor
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
No red colour in my lg lcd monitor ..red colour setting doesnt bring any change i screeen..pls suggest some solution
it is very simple, by default in monitor circuit RGB (Red, Green, Blue) tube is installed. and in combination of both of three colors we are able to view colorful image. due to non functionalty of Red color u r not able to view red color in screen, either you replace picture tube or purchase new monitor. coz cost of this tube is equal to monitor.
Jun 05, 2009 | LG Flatron F700P 17" CRT Monitor
Monitor colour problem
the VGA cable connecting from moniter to the computer is faulty so replace new
May 25, 2009 | Samsung SyncMaster 793MB 17" CRT Monitor
Green color missing from my LG 700s model
as you are electronics engineer so let us discuss technically.
as you are unable to see green colour means you might be seeing picture of magenta colour
as technically
red+blue = magenta
crt has got three cathodes
your two cathodes circuit is fine one ckt that is green cathode circuit is not working.
for that problem your will have to check
  • cable from computer to monitor
  • loose contact in crt base.
  • crt connector loose
  • voltage on green video output.
  • green video output transistor might be defective.or print loose.
  • circuit related to green video ckt
  • green video signal coming to green video ckt.
  • & finally crt defective (in rare case.)
  • hope this will help
  • good luck.
Oct 16, 2007 | LG Studioworks 700S 17" CRT Monitor
HP Compaq FS7600 17" CRT Monitor Logo
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
