Question about HP Compaq FS7600 17" CRT Monitor
I have an HP7540 monitor that I need to be able to change red, blue and green colors on thru the menu
Posted by lstetler on
Piyal Perera
  • 528 Answers
I hope you know how to enter and navigate through the OSD (On-Screen Display) menu of your monitor.
Enter the menu and navigate to 'Color' menu.
Under that select 'User'.
Now you can select either Red, Green or Blue.
After selecting a color it can be increased or decreased.
Press Exit button to go back, select the next color and set it to your liking.
Posted on Sep 08, 2011
How to change red blue and green color on monitor hp7540
Press the menu button on the monitor, should be the far left button...use the minus and plus buttons to scroll thru the menu. Select the function you want by pressing the far right button (not the power). The function you want is the one witht the temp icon and the letter "K". press the far right buttion again and use the the plus and minus buttons to adjust the level.
Hope that helps.
Tom Miller
Broadcast Engineering
Sep 08, 2011 | HP Compaq FS7600 17" CRT Monitor
@the monitor appearance changed to pink shade and we are not able to see in this colour pl give me a solution to sent it back to normal mode
probably the color setting of the monitor has been changed.
on the monitor panel press the menu button and go to the color option.
see if increasing or decreasing the RED GREEN and BLUE color options sets back the monitor to normal.
usually some monitors have a reset option also, by selecting it everything will get back to normal.
Aug 02, 2011 | Computers & Internet
I need help with the color there is no red or green went thru the manual and the sample colors are ok, went back to regular program and colors are terrible,
check you cables like a VGA monitor you have three colors Red Green Blue on the cable and if one is broken then the color will not come in correct. on your device that feeds video to the tv try some different cables and inputs it might be a bad cable
Jan 02, 2011 | Philips 42PFL3704D LCD TV
I have a tv that only shows variations of blue and yellow no matter what i do to the menu color options. However the menu will show all of the colors but not the normal screen.
it sounds like an rgb problem it depends what your playing thru your tv but if its coming thru a component lead eg red green and blue it sounds like your missing the red feature also it could be a pin bent on your scart which is carring the red portion of the picture , What kind of set is it and what are you playing thru it ?
Mar 02, 2010 | Akai LCT2060 Television
The monitor has now got a blue tint I have checked the lead
Your monitor has a menu system that will allow you to access the color guns so you can adjust the red, blue, green guns that create the color picture.
The blue tint may indicate that you need to adjust teh reg and green to offset OR it may indicate that you have lost the red gun all together.
If this is an older monitor and you are considering repair... cost points say it is cheaper to buy a monitor ~$60 bucks
Oct 03, 2009 | Computers & Internet
The colors on my monitor are faded/bright always changing.
Right click on your desktop (not an icon but a blank space), click "personalize", click on the tab on the far right(settings), click the drop-down menu on the left side above the colored banner, make sure it is set to the most colors(usually 32). If you need a walkthrough for Vista I can provide that as well.
Jun 14, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Display does not show the color green. Green comes in as black
why not use a known good monitor
in 1 minute flat the truth.
not only that you can move or bad monitor to another pc
and see if it works.
also the cable can be bad.
Mar 13, 2017 | HP VF15 15 in.
HP Compaq FS7600 17" CRT Monitor Logo
Top HP Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
