Question about Xerox Phaser 8560/YN Printer
I am getting the following error. 09,038,46:15008
Posted by hurblin_mich on
guilopmar
  • 304 Answers
09,038,46:15008
Ink count flag stuck after melting 2.5 Black Ink Sticks.
Initial Actions
• Check that the Ink Sticks are genuine Xerox.
• Check for obstructions in the Ink Wells.
• Check the Ink Loader data (P/J0150) and power (P/J5) connections.
• Verify the Ink Sticks advance in the Ink Loader.
• If the problem persists, follow the procedure below.
Troubleshooting Procedure
1 Check that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Are the Ink Sticks loading properly?
Yes) Go to Step 2.
No)Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. This must be performed following an ink loader replacement.
2 Test the appropriate Ink Melt Heater. Run the Service Diagnostics Ink Melt
[1,2,3,4] test.
• 1 = Yellow
• 2 = Cyan
• 3 = Magenta
4 = Black
Did the test pass?
Yes) Replace the Printhead
No)Replace the Ink Loader.
Posted on Sep 08, 2011
Lately I've been always getting the following error "10086 - Error Invalid Number......."
your number input is wrong or maybe you have a key pad error.CONTACT SAMSUNG TECHNICAL
Sep 14, 2015 | Samsung Glaxy SII i777
I am getting error code 0x80070005, how do i fix this
Windows Activation Error : Error Code 0x80070005 I have upgraded my x64 Vista to x64 Windows7. After adding to companies domain, it asked to activate windows again. but its giving the following error when i try to activate it : "Windows Activation Error : Error Code 0x80070005"
The link for the fix is described at the Microsoft Website, link listed below.
http://answers.microsoft.com/en-us/windows/forum/windows_7-windows_install/windows-activation-error-error-code-0x80070005/90fb852d-a507-4c76-a672-0be2ecbdb320
Sep 30, 2013 | Toshiba Computers & Internet
Dban problem ( crash : "dev/sda" )
Use fdisk and / or format from command prompt. Easy and no fuss. gl
Nov 03, 2012 | Computers & Internet
Ip4600 the following tank cannot be recognized
This a problem that is to be sorted by the seller of the ink cartridges.
Take care!
damnor01
Apr 28, 2012 | Canon PIXMA iP4600 Color InkJet Photo...
I am using a netgear stora network drive and whenever I try to access it remotely I get a language error code window. It says, Language Error The following error occurred: Unable to load...
You get this error if you set up through the browser window instead of the CD software. To fix change your language in the user preferences to another language, save and then change back to english.
Nov 25, 2010 | Computers & Internet
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
Everytime i log out of the internet i get the following error coming up on my screen 'iexplore.exe application error' when i click on this to get rid of it i then get an 'runtime error' message and...
Goto Control Panel>>Internet options -Uncheck the following options Disable script debugging(Internet Explorer) Disable script debugging(Others)
Enable third party browser extensions
Mar 17, 2009 | Computers & Internet
Getting Error Message during game play.
There is a guide that you can get that will solve all errors like this and black screens it has been a lifesaver for me. Have a look at http://www.freegamesforwii.info/?cat=11 they have info on where to get this guide. I cant remeber the site off the top of my head,.
Hope this helps
Mar 03, 2009 | Nintendo Video Game Consoles & Games
Xerox Phaser 8560/YN Printer Logo
390 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
