My dishwasher is less than 1 yr old is starts fine and after about 10 min the cancel/drain light comes on and then it shuts off. the water does drain out but just is not completing the wash. I have tried many different setting heavy duty, normal, light, and 1 hr and same thing happens every time
With the dishwasher door closed and the unit in standby mode or with no cycle selected and all lights off, press - heated-dry, normal, heated-dry, normal buttons in that sequence. Then press cancel..... wait until 2 minute cycle is done. Open and close the door and make sure it is closed. Then run another cycle.
1)check the blockage in drain.(any block in drain hose)
2)check the drain motor working.
3)remove the water manually and start up.(if it works may be on the drain pump problem)
Watervalve open?
If yes?
Has this unit an integrated waterstop with the hose interlocked with a flow detection device? Mine failed on that. Bought a new machine after 10 year of service the flow device was 300 dollars.
It sounds as if there is something in the bottom part of the dishwasher arm (it sprays the water around the bottom of the dishwasher). I would suggest that you take out the baskets and then remove and clean all of the parts that water comes out of as well as the bottom drain. If this works or does not, I would also suggest that you run an empty load using 1/4 cup vinegar. Hope this helps!
If you do have the Touch Control Electronic Pad, then you do have a problem, moisture related. You need to open the panel, use a Hairdryer to dry the panel properly and replace. This sorts many of these Touch Control Electronic Pad.
Sounds like the electronic controls (smart card) are acting up. Try shutting off the power at your fuse box or shut off the circuit breaker for 1 minute them turn the power on again. This fix quite often works on electronic appliances.
Joe, see if you can reset the board by pressing heated dry-normal-heated dry-normal..(new board). Old board is high temp wash-air dry-high temp wash-air dry. See if it goes back to normal. If not you probably have a stuck or shorted keypad on the overlay..not the board. Catriver...post back
