Check the small lock switch on the adapter usually located on the edge of the adapter. check and see if in lock or open position. if its in lock position toggle the switch to open position and you should be able to read as well as write date to and fro from the sony memory stick pro duo adapter. good luck
SOURCE: Memory Stick Pro Duo 8GB on PsP
Two possibilities.
1. The firmware on your PSP is too old to recognise the 8GB (only recognises up to 4GB).
2. If firmware is up to date you have a fake memory stick (easy way to check is to check the info for the memory stick on your PSP if its says that MAGIC GATE is unknown rather than supported then it is fake.
The fake ones typically double compress the data so that it appears to have 8GB when in reality it does not.
SOURCE: Sony memory stick PRO Duo is not working
try formatting it on a pc in FAT file system or run a deep scandisk
SOURCE: Misfunctioning 4GB memory stick pro duo
Are you formatting it with your computer or PSP?
It that doesn't work - try formatting it with your computer.
SOURCE: sandisk 2gb memory stick pro duo wont format
it means it is containing some virus...try to format it with some other system..but it is a frequent problem...try to delete the files while in the phone and format using the computer...its better to claim warranty if it has....
is this cleared your problem?
