Question about Activision Video Game Consoles & Games
Installshield 1628 error - Activision Video Game Consoles & Games
Posted by guren_r2 on
1 Related Answer
Anonymous
  • 171 Answers
SOURCE: Cd won't install Installshield error 1628
You do not need the CD to install the wireless router.
Assuming you have a dsl or Cable Internet connection established already, lets get you setup.
Plug the cable provided with the router into the cable/dsl modem.
You will need additional cable, for now, to plug your laptop into the router. Please do so now.
Your router will automatically assign an IP address to your laptop. It sould be 192.168.1.100
Your router will automatically assign an Gateway address to your laptop. It sould be 192.168.1.1
Your IP address is your physical address to therouter, Hense to the cable, Hense to the Web. Hense.
The Gateway IP is the actual IP used as the Gateway to the cable/DSL modem, hence, this is your actual connectivity. OK, let's get serious. The cable modem gets its IP information from you cable/DSL provider. This information is then collected by the router and the router assigns a local address thus allowing you to connect more than one device, (i.e. computer, printer, camera) and gain Internet access from that router. Its kind of like spoofing or fooling the system into thinking each device has its own address from the cable/DSL provder and allowing it to have a connection to the Web. I explain this as I feel understading how the router actually functions weill enable you to better utilize thenetwork and also protect your computer and devices from outside attacks.
An example:
The cable/DSL provider will provide the following:
IP: 72.60.55.10
Subnet: 255.255.255.0
Gateway: 72.60.55.1
Your Linksys Router takes this information, and makes it the base IP for its setup. It then allows you to assign a local address block for your network devices, called "Private" IP's. These are IP addresses that cannot or should not be found on the Internet.
An Example:
IP: 192.168.1.100
Gateway: 192.168.1.1
In the above example the Gateway address of 192.168.1.1 is the physical address of the router. To verify this information Go to Start, Control Panel, Network, Locate your Local Area Connection. This is always the wired network card in your laptop. You should also see one for your wireless network card. We will not yet be working with this device, but remember where it is as we will be working with it soon. Right-click on the Local area connection and go to Status and left-click. On the tabs at the top of this window, click on the support tab. You should now ba looking at the addresses I talked about earlier. And if all is well, you quite possibly could be able to open your browser, Internet Explorer or Mozilla or Safari and access the Internet. Having said that let's configure the router.
I am going to take a short break and hope you understand all I have spoke of. I await you response and any questions you may have.
My name is Todd and I am here to help you. We will get you up and running in no time.
Posted on Oct 07, 2008
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
I can't uninstall a software from my notebook with windows 7, 64bit. The error code is 1628.
download this http://www.techsupportforum.com/forums/external-link/?link=http%3A%2F%2Fcleanup.stevengould.org%2F and then try again :)
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Feb 11, 2012 | Computers & Internet
Errorvalue c000009c disk type 5 i had flexerasoftware install shield 2010.exe from saturn.installshield.com i down loaded it but my computer won't let me use it can you help me i hope so. mary ...
Looks like a dll registration failure and/ or a Permission problem.
  • Please go to your Event Viewer. (Start -> Run -> Type in Eventvwr.msc and hit enter)
  • Go to Application category
  • Check for the Errors (Red X) and read the description and make sure that program is the one returned the error
  • Post here the errors with details.
  • You can use this Link to browse or ask for assistance from InstallShield
Thanks and have a good day! -Lasitha
Jul 17, 2010 | Computers & Internet
Error 1607 unable to install InstallShield
how you fix it
Reinstall the InstallScript engine loadTOCNode(2, 'resolution'); To reinstall the InstallScript engine from InstallShield Developer, follow these steps:
  1. Download the ISScript7.zip file. To do this, visit the following InstallShield Web site: http://consumer.installshield.com/kb.asp?id=Q108322 (http://consumer.installshield.com/kb.asp?id=Q108322)
  2. Extract the ISScript7.zip file.
  3. Double-click the ISScript.msi file.
Running Setup from a virtual drive loadTOCNode(2, 'resolution'); If you are running the Setup program from a virtual drive created by using the SUBST command, you can delete the virtual drive and instead run the Setup program from the physical hard disk. To delete the virtual drive, click Start, click Run, type subst drive_letter: /d, and then click OK.
good luck
Mel
Jun 05, 2010 | Microsoft Windows Vista Home Basic for PC
I just installed windows XP service pack 3, installshield errors
Hi, "I hope this will help you out with the problem! Try this Link: http://www.technospot.net/blogs/download-directx-10-for-windows-xp-from-alky-project/ "If this help? Feedback is appreciated, thanks paul7of9."
Feb 04, 2010 | InstallShield Update Service Version 3
Installshield 3 Help (maybe)
I didn't get a solution but the project was dropped. I don't have to do this install.
Sep 19, 2008 | InstallShield Update Service Version 3
1628 software installation error
you need MSI installer files this will fix the 1628 problem
Dec 25, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Error Containing "0x123454" when installing software
Any error code beginning with "0x" is related to a problem with incompatibilities with the InstallShield program which is used to install all of the components. To fix this find the "InstallShield" folder on the computer (the location varies by computer OS, but is generally located in "c:\Program Files\Common Files\") and move the contents to a new folder on the desktop of the compter. If everything works well you can discard the new folder (and the old InstallShield contents). Run the Nikon installer again and it will install properly.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Video Game Consoles & Games Logo
69 people viewed this question
Top Activision Video Game Consoles & Games Experts
Muntejaya Ginting
Muntejaya Ginting
ray gallant
Are you an Activision Video Game Console and Game Expert? Answer questions, earn points and help others
