You need to go into BIOS by pressing an F key during boot. Look on the screen for correct Function key. Check if BIOS still recognizes a hard drive. If not, you need to physically reconnect drive and try again.
SATA HARD DRIVE - XP INSTALLATION The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH. 2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM 2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD. BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
It sounds like the HDD controller may be bad.When you thought it was the OS having a problem it sounds like the controller was going out.Unless the HDD you were connecting to it was bad.
You will likely need to go to Toshiba's website and find the driver for your drive controller. Save it to a USB flash drive, and load it during the Windows Installation by pressing F2 or F6 (whatever the prompt indicates) when it asks for additional drivers during installation.
You can download any/all the Windows Vista device drivers for your model laptop from the Toshiba WEB site from their download page. Make sure you enter the model of your laptop so you can get the correct drivers. Use this link :-. http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp#
Hi, i have the same model TOSHIBA protege s100,
i cant installing a fresh copy of Windows XP Pro onto a Toshiba Portege S100 laptop. the error is "Setup did not find any hard disk drives" Please reply Thanks [email protected]
Guys, if you have the genuine XP CD, please download the Storage Driver from Intel and slipstream it into your version of XP CD. You can also slipstream Service Packs into it as well.
Personally I hate Vista so much. It really brings out the angry devil in me.
By the way, the best and easiest way to slipstream is to install and use nLite http://www.nliteos.com/
Let me know if you want help on installing XP on R500 (I build it a few days ago, but regret to update the BIOS to version 1.06 as I lost the Ctrl key on it).
To get to the BIOS, press and hold the Esc key then Power button.
