Question about Breadman TR2200C Ultimate Bread Maker
I need a paddle for my TR2200C Breadman machine. Where can I get one and how much will it cost?
Posted by dnbartschi on
Lance Hill
    Genius:
  • 1,739 Answers
You should be able to order a replacement paddle for your TR2200C Breadman online from the following site:
http://www.directpartsandproducts.com/bread-makers-tr2200c-c-61_129_837_838_841.html
Price is listed at $5.95
Posted on Sep 18, 2011
2 Related Answers
Anonymous
  • 134 Answers
SOURCE: Need a paddle for the breadman TR2200C
HI
You need to contact these people
https://secure.prodregister.com/prodprotect/applica/bm.shtml
The phone number for spares is here
Rob
Posted on Feb 14, 2009
hmerchant110
AliTech110
  • 7191 Answers
SOURCE: Breadman Ultimate TR2200C needs the
You can download and print the complete instruction manual and recipe book in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
To order replacement parts, kindly call Fox International (Breadman customer care partner) on:
800-738-0245 (Monday-Friday, 8:30 AM to 8:00 PM, E.T.)
You can also order replacement parts by sending an email to: [email protected]
Hope this helps you. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
Posted on Oct 16, 2010
I need a Kneading Paddle for my Breadman Ultra bread machine the Model # isTR700/600a
You may be able to order a replacement online from this site:
http://www.directpartsandproducts.com/bread-makers-tr700c-c-61_129_837_838_855.html
Recommend you check with the supplier to verify that the available paddle for the TR700C also fits your TR700/600a.
Thank you for using FixYa!
Jul 27, 2011 | Breadman TR2200C Ultimate Bread Maker
NY Breadman Ultimate TR2200C stopped working. The "gear shaft" on the bottom of the machine no longer turns. Any suggestions?
Hi, Take the pan and paddle out of the machine and see if you can turn the paddle freely by hand. If no, then the sealed bearing has failed and you will probably need a new bread pan. If it turns freely then it could be the belt is loose or has fallen off. Belts and motor are located in base of the machine. Unplug machine before working on this part. Hank
Oct 31, 2010 | Breadman TR2200C Ultimate Bread Maker
The kneeding paddle is no longer smooth.where can
If the paddle is sticking it could be the sealed bearing on the bottom of the pan is sticking. Either that or the belt is loose and not allowing the paddle to spin freely.
Hank
Feb 08, 2010 | Breadman TR2200C Ultimate Bread Maker
My Breadman bread maker is broken. The pan jumps
It is likely that, due to a poor design the contact between the paddle traction and the machine is worn out.. Check it and you will see that the bare metal is shiny there in the two bumps in the rotating plate in the machine.
I used a dremel-like rotary tool to grind the contacting part so that the contact between the machine and the paddle traction is orthogonal.
Worked fine for me.
Regards
Nov 16, 2009 | Breadman TR2200C Ultimate Bread Maker
HI
Rob
Feb 10, 2009 | Breadman TR2200C Ultimate Bread Maker
Need breadman plus mixing paddle
You can order a replacement paddle for your Breadman bread maker at http://www.abtecparts.com/Breadman_breadmaker_paddles.htm
Sep 21, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C ultimate paddle
Breadman 20274 paddle fits this model- first one that pops on Amazon .com
Sep 02, 2008 | Breadman TR2200C Ultimate Bread Maker
Need to replace the pan on a breadman tr2200c.
Call the customer service number 1-800-233-9054, a new pan with paddle was $51.40 with shipping.
Jun 23, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman replacements paddles
http://www.nextag.com/breadman-tr2200c/search-html
there is one available at this link.
Mar 04, 2008 | Breadman TR2200C Ultimate Bread Maker
Breadman TR2200C Ultimate Bread Maker Logo
Top Breadman Kitchen Appliances - Others Experts
Tom Chichester
vtec
Are you a Breadman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
