Belkin F5D8236-4 Router Logo
Question about Belkin F5D8236-4 Router
Help me with my wep key please - Belkin F5D8236-4 Router
Posted by jordansherro on
Anonymous
    Scholar:
  • 114 Answers
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Posted on Sep 08, 2011
I set a WEP key for the USB, now it's not allowing me to connect, Is their anyways to reset the WEP key of the dongle ? Please Help me.
If it's a standard WIFI dongle it would have come with an installation disk or on-board self installing drivers and (usually) a WIFI app which I presume you used to set the WEP key. If it's a modern one you will be using a MINIMUM of WPA2 and TKIP or AES encryption. Try running the setup app again with one of these settings. The app SHOULD give you the choice of setting up encryption & passwords using windows instead (windows zero config usually) by right clicking on wifi symbol in bottom R of screen. I find that more reliable. Check the maker's spec for the relevent protocols. Good Luck.
2answers
What the wep key
Usually the default WEP key is a manufacturer password that your router is provided with. Can be found sometimes on a label sticker under the unit back cover. for a specific WEP key please visit Belkin support site and choose the right model number. for more details regarding WEP key please have a look here http://compnetworking.about.com/od/wirelessfaqs/f/wep_keys.htm or just check it on Wikipedia for a more comprehensive guide.
I am trying to install a wireless printer and need the wep key. Can you help please?
Sorry no one has helped you so far but this is a common question.
The WEP Key is usually found on the wireless modem itself. Usually on the bottom of the device. This is one of the reasons that WEP is not very secure.
If for some reason its not there it can also be found by opening a browser window and loading your modem access page (usually at address 192.168.1.1 or something close to this it depends on the modem).
There, under your wireless settings you will find the WEP Key and SSID etc.
If this doesn't help please re-post with more info. Like your wireless modem make and model and we can work from there.
I want to go on Wi-Fi at home but I do not know my WEP Key. Can you help me?
Greetings Fussdragon,
Fortunately, the WEP key can be easily located. If you have not changed your router from factory settings, the WEP key can be located on the bottom or back of your router. It consists of a combination of letters and numbers. If further assistance is required, please feel free to contact me. Thank you for using FixYa! =) Please rate.
I cant find the wap key to connect to xbox live i ahve a sky wireless router help!!!!
Greetings Joecosens,
Fortunately, the WEP key can be located on the bottom, or backside of the router. If you have changed your router from factory settings, your WEP key is whatever you have changed it to. But if you have not changed it, then it should be on your router. The WEP key is a combination of letters and numbers. If further assistance is needed, please contact me directly. Thank you for using FIxYa! =) Please rate. Kindest regards.
2answers
Cant find my wep code for netgear router
HI,
Please visit the below link to check your WEP key:
WEP key
Hope this helps.
Regards
Anand Gupta
Ok. so im trying to get my WEP key for my PS3 so i can have the inthernet....but i have no idea where or how i can find my WEP key. Please help
The WEP key is going to be located in one of the menus of the wireless router your using. Look at the manual for your router and you will find out the address to type in your browser to get to your wireless router menu. Then from there you can find the WEP key.
Whats the 2WIRE_493 WEP key for playstation?. I tryed hooking up my playstation three but I dont know the WEP key for 2WIRE_493 can you please help me?.
Your WEP key is set by a user of the household you would have to go in to your personal router page where you can change ports etc. and reset it to whatever you want.
Psp not accepting wep key
You need to choose the correct security setting before you enter the WEP key where it asks you if its WEP. ASCII or unencrypted choose the correct one!
How do i find my WEP key, I have a Belkin 54g router
hi im an xbox live support representative
you could actually just call your router manufacturer so they can provide your'e wep key
if you still have some issues just call xbox customer support
thank you
Top Belkin Computers & Internet Experts
Donivan Wise
Mike
Steve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
