Car Audio & Video Logo
Dean R Posted on Sep 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I own a Blaupunkt Atlanta CD85 car stereo. All the buttons on the faceplate work, but a couple are twisted or out of alignment. I want to open up the case and readjust them but don't want to damage the unit or the locking clips. There are four small screws going into the back of the faceplate and ten locking clips around the perimeter. I'd like to know how to release the locking clips and whether or not I need to remove the screws as well to open up the case. Thanx.
kenw392
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Blaupunkt Master 2,226 Answers
  • Posted on Sep 08, 2011
kenw392
Blaupunkt Master
Level 3:
Renaissance:
Answers
2226
Questions
Helped
473844
Points
4986
The screws definitely need to be removed. I usually use my finger nails to pry open the case of the face.
I have a Blaupunkt cassette car stereo fitted to a Rover Metro (M reg) which claims to have an AUX mode, but I can't for the life of me figure out where the input might be. Am I being dumb? The stereo says...
Some car stereos have aux output at the back, so i reckon you have to remove unit to check it, it must be one 3.5 female, or 2 RCA connections (red and white).
The yellow wire goes into a black box. A yellow
Yes, the black wire goes to ground.
Yellow - Constant 12v.
Black - Ground (MUST hook up! NEVER let your antenna pull the ground)
Red - Switched 12v through the ignition
Replaced battery in my 03 ford focus now my car stereo will not power on. any procedure to reactivate my car stereo to turn. been reading horror stories about this setup. ugh!!
Not sure if this will help you , but many aftermarket have a reset switch behind the faceplate. would be a small hole about big enough to poke the tip of a ball point pen into.
Also , remove the faceplate and replace it making sure it is clicked in securly.
Sony XR-C2600 car stereo stuck in demo mode
Sony XR C2600
  • Press release button on faceplate.
  • Remove the faceplate.
  • Clean the contacts in system and faceplate with alcohol.
  • Voila, all button works now
Bullet Sankar India
Lights on blaupunkt automotive stereo faceplate not working. probably blown out lights. model is cambridge cd 125. any chance of replacing them myself? where do i get the parts.
Very trickey to replace bulbs as they are very small....any good electroinics outlet would have them in stock p.s the need to be soldered in
1helpful
2000 Astra Blaupunkt Stereo
Leave SWITCHED ON...UNDISTURBED for a couple of hours
Fade button - does this system have one?
You can download an owner's manual for your CD player from this link: http://www.blaupunkt.com/us/downloads_1.asp
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
