Question about TruTech PLV16260 Television
Red light when plugged in and then nothing when push power button on the remote have to unplug and replug to get red lite
Posted by dhoppy1954 on
Tyler Bearor
    Champion:
  • 367 Answers
Did you get this fixed?Please let me know.Thank You very much!
Tyler
Posted on Sep 17, 2011
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Proscan LED TV Will power up the red standby light & standby on amber when turned on but does not show picture or sound unless I unplug and replug over
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Feb 14, 2016 | Proscan Televison & Video
Lighting was bad in my area and my tv was plugged inns surge protector the tv turned on bit the power light blinks with the opc light my dish won't how up on the tv what do u think is wrong??? I turn...
The tv have a problems with the board that called the tv main Tuner signal board.That the board where the tv incomming broadcasting signal cable plug into it.This tv it still useable.I have one too a 46".Try tv unplug,replug it back like about an hour this problems will solved for a while evenually will return though.Every times POWER and OPC LED lights flashes,just push the tv power button ON again on the remote and have to wait,sometimes tv it will lite up and work right away.Sometimes it will have POWER and OPC LED lights flashes again.Just have to push the remote power button ON again and wait a while again eventually tv it will lite up and work.Have to this like 3 or 4 times power ON button pushes somtimes,tv will eventually work though.I know i do this manytimes before my tv have this problems off/on 3 1/2 years.But finally u will have to replace the tv main Tuner signal board sooner or later though this solution dosen't work for the rest of the tv life.U can do some basic mechnical works like take things aparts and putting back together again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Turner signal board for the replacement.
Sep 02, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Re:toshiba 55h70 tv i unplugged the tv to paint. when i plugged back in a wk later i have no picture or sound. nothing. can't access the menu - completely dark screen. the red lite "on" button...
I would check the fuse on the main board. Check the Capacitors on the Power Supply board. Seeing that you unplugged it and replugged it in you might have bad caps that were weak to begin with. Please learn how to safely work on a TV before attempting . Even when a tv is unplugged it has enough power to kill you. Discharge all Capacitors first. make sure its unplugged of course.
Jan 06, 2011 | Toshiba 55H70 55" Rear Projection...
Plugged in tv after b eing in storage and nothing is happening, outlet is good.
Unplug unit. While unplugged, hold power button in (not on the remote, but on the actual tv), for 10 seconds. Replug and retry. If nothing happens, power supply is probably dead. Repair or replace.
Aug 09, 2010 | Sony Televison & Video
MY Toshiba 65H93 doesn't come on.When I press the power button nothing happen.But when I unplug the it from the AC outlet and plug it back into the AC Outlet I here a clicking sound, but the set still...
Same here! Just happened yesterday after we had a power outage in the neighborhood and when the power to the neighborhood was restored my 65H93 would not power on with the remote or the power button on the front of the TV. I get the same clicking sound when unplugging and or pushing the reset on the front of the TV. I also see a red light come on inside for about a half a second after hitting reset or unplug/replugging it in. I'm thinking it has something to do with the standby circuit not coming on due to some problem with the power supply/circuit board?
Have you found out anything yet? I'll let you know if I find out anything also.
Thanks
Jul 18, 2010 | Toshiba 65H93 65" Rear Projection...
Rca rt2870 wont turn on
a fuse may need to be replaced
Jul 31, 2009 | RCA RT2280 System
TV will not Turn On.
same thing,tv won,t come on,unplug the tv, nothing at all,just yesterday my tv was fine, this is the first time this has ever happen
Mar 13, 2009 | Samsung HC-P4363W 43 in. TV/DVD Combo
Tv wont turn on
take your tv to technician who can check your power supply, if your power is coming on and off, than a problem is not as big. firstly let him check a ht of a supply constantly, your supply is cutting.
Nov 03, 2008 | Panasonic CT-32SC13 32" TV
Open Questions:
See all TruTech PLV16260 Television Questions
TruTech PLV16260 Television Logo
46 people viewed this question
Top TruTech Televison & Video Experts
Eric Rotmil
Eric Rotmil
Marvin
Marvin
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
