Question about Sony Cyber-Shot DSC-S75 Digital Camera
I have a Sony DSC-S75 camera and I am having a problem finding a memory stick are any of the SDHC cards compatible/
  • 489 Answers
The only memory card you can use are the Sony Memory Sticks. You cannot use a Sony Memory Stick Pro, so you have to find one that is under 512MB capacity and does NOT say "Pro" on it. You cannot use any other format memory card such as SD or SDHC.
Thomas
Posted on Sep 07, 2011
What memory sticks do i need
Quoted from the technical specifications available on the Sony website UK. http://www.sony.co.uk/electronics/cyber-shot-compact-cameras/dsc-h300/specifications Storage Media Internal MemoryApprox.55MB Compatible Recording MediaMemory Stick Duo, Memory Stick PRO Duo, Memory Stick PRO Duo (High Speed), Memory Stick PROHG Duo, Memory Stick Micro*10 , Memory Stick Micro (Mark2)*10 , Memory Stick XC-HG Duo, SD Memory Card, SDHC Memory Card, SDXC Memory Card, microSD Memory Card*10 , microSDHC Memory Card*10 , microSDXC Memory Card*10
Mar 26, 2015 | Sony Cyber-shot DSC-H300 Digita Camera -...
Will sony cybershot dsc w110 support sdhc card
No, the DSC-W110 does not support SDHC cards. You have to stay with Memory Stick Pro Duos.
Jul 26, 2012 | Sony Cyber-shot DSC-W110 Digital Camera
I have a Sony digital camera model # DSC S75. I would like the largest memory stick available for still photos. I get confused with GM and MB. I found one for 32 GB, is that the lrgest and about how much...
I did a bit of research on this, and you're going to have to be very careful. Your camera is only compatible with the very first generation of "memory stick". That sounds like a generic term, but it's actually a Sony specification. Please take a look at the wikipedia page on memory stick, and note all the newer versions. Also note that the 'memory stick' is no longer manufactured. Here is a list of memory sizes, I agree that the Mb and Gb are confusing. Each one is double the size of the one before.
8 Mb
16 Mb
32 Mb
64 Mb
128 Mb
256 Mb
512 Mb
1 Gb
2 Gb
4 Gb
8 Gb
16 Gb
32 Gb
64 Gb
Now, you will have to find a genuine Sony "memory stick" and not the Pro, or Duo, or anything like that. When they were manufactured, the largest one was 128 Mb, so that is the limit for your camera. Anything in "Gb" or Gigabytes cannot be a memory stick. I did find 128Mb memory sticks on Amazon. The review page on DPreview will tell you how many pictures you can store on a card half the size, just double it.
Feb 10, 2011 | Sony Cyber-Shot DSC-S75 Digital Camera
My DSC-S75 camera doesnt recognize my new buy memory stick duo... what shall i do
the card maybe can't compatible with your camera if you are sure you have place it right. cameras have some requirements of the card: capacity and format there is a scope of the capacity of the card for one camera. and there are 3 type of the card format: FAT, FAT32, and NTFS. the first 2 are common for small electronic products, and the last for computer.
Jan 07, 2011 | Sony Cameras
Where to purchase a memory stick for Sony Cyber-Shot DSC-P71. Every card I have seen is not the same size as the current one I have
The DSC-P71 Camera is compatible only with the 32MB / 64MB / 128MB Memory Stick Duo only. Standard Memory Stick media cannot be used with this Camera.
It's bit hard to find out these Memory Sticks as most of the Companies discontinued manufacturing low capacity Memory Sticks. However you can try contacting a Sony Store or any Sony dealers near your area to get one.
Aug 07, 2010 | Sony Cyber-Shot DSC-P71 Digital Camera
My Sony DSC-S75 camera shows a format error when I insert my 128MB memory stick also blinking is C:13:01. Any idea's how to fix? Thanks!
Format error display shows memory card is unstable and need to be format through format option in Camera menu.
Format memory card, if that does not fix the issue, try another memory card in camera and check this memory card in another camera just to make sure either camera got problem or memory card is bad.
Jan 01, 2010 | Sony Cyber-Shot DSC-S75 Digital Camera
Memory card error for sony dsc-s75 camera will not accept memory card
Format the card in the camera. Download any pictures still on the care first using a cardreader if necessary.
Aug 12, 2009 | Sony Cyber-Shot DSC-S75 Digital Camera
Memory Stick problem with Sony DSC-P2 Digital Camera.
Hey stevekschan,
You should be able to use any kind of Memory Stick you want. BestBuy.com has many sizes of memory sticks available.
Sincerely,
Allan
Go Ahead. Use Us.
May 07, 2008 | Sony Cyber-Shot DSC-P2 Digital Camera
Memory card
Hi - no, the DSC-P7 isn't compatible with Memory Stick Pro, only original Memory Stick, meaning you're limited to 128MB/stick. Having said that, the P7 is only a 3.2MPixel camera, 128MB will hold quite a few pictures, even at full resolution.
Oct 26, 2007 | Sony Cyber-Shot DSC-P7 Digital Camera
Dsc-s75 capacity
The 85 and 717 were the first cams able to use a contigous 256Mb Pro stick as far as I know, the 707 and 75 are stuck with the originals or the Switchable ones which defeat the object as if you've gotta pull it to switch "halves" you may as well take 2 normal and cheaper sticks along..
Sep 11, 2005 | Sony Cyber-Shot DSC-S75 Digital Camera
Sony Cyber-Shot DSC-S75 Digital Camera Logo
118 people viewed this question
Top Sony Cameras Experts
Vish Iyer
Vish Iyer
 Larry
Larry
 MikeWang
MikeWang
Are you a Sony Camera Expert? Answer questions, earn points and help others
