Panasonic SV-AS10 Digital Camera Logo
Posted on Sep 07, 2011
I can't access my device with any computer, if i connect it to the pc it doesn't work, it wrote set it to play mode and when i set it to play mode it doesn't work.. and please how do i get the it software to install on my pc.. and am in Ghana W/A.... TANK U
1 Related Answer
Anonymous
  • 2574 Answers
  • Posted on May 13, 2011
SOURCE: My panasonic lumix dmc-fx01 has
Navigate to this page ..>Panasonic Lumix Dmc-Fx01 service manual and go to page #20 Disassembly and Assembly Instructions.
1helpful
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
1helpful
My volume button broke
1 Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip, if you're device isn't working properly or there's a frozen display. Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off. If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
2 Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager." This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button. Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode. Click the "Repair" button when it appears on your computer, then follow the steps to fully recover the GoGear. Properly disconnect your GoGear from your computer and restart the device.
3 Recharge your device if your GoGear dies suddenly while playing. Connect the GoGear to your computer via the supplied USB cord. Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on. This will begin the charging process of your GoGear. If recharging doesn't work, the battery may need to be replaced. Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
Can't ping internal page
It may be that the WAP was set-up to use a different subnet from the default.
Check the IP address that is assigned to the computer that is connected to the router and substitute the first 3 octets (192.168.10 is the default) with what your computer reports. So, if your computer has an IP address of 192.168.22.32, then use 192.168.22.100 instead.
If that doesn't work, you will probably have to do a factory reset on the device to get it to use the default address.
Downloads for this device are available here: (click here)
8helpful
3answers
Download from lg800g to computer
Is your Micro USB cable a "B" or "A"?Micro USB "B" is for data/charging.
Micro USB "A" is for charging only and will not work for any kind of data transfer (pins not connected).
The connector will be labeled at the micro usb end.
When you plug the cable into your phone a popup will ask you if you want to connect to mass storage. Once you answer yes, you can connect to the phone just like a usb drive.
How do I pair Jawbone headset to Samsung Galaxy S phone
Follow these steps to pair your iOS device:
  1. Turn Bluetooth on (from the Bluetooth menu on your iOS device)
  2. Put your Jawbone device into pairing mode (click the link below to access instructions for your device)
  3. Wait for your iOS device to detect your Jawbone
  4. Tap the Jawbone device name in the Bluetooth menu to connect
1. To begin, access your iOS device's Bluetooth menu:
  • From the Home screen, tap Settings
    • Tap General (for iOS 5 or older)
    • Or tap Bluetooth (for iOS 6)
Oct 25, 2017 • Cell Phones
1helpful
I cannot get my keyboard or my mouse to work with my dell computer. what can i do?
Please add more information to get specific assistance. Are these wireless devices? If wired, do they use USB or PS/2 connections.
For wireless devices, try replacing the batteries and resynching to the receiver. (You may want to check putting the receiver in different USB ports.)
For wired devices, disconnect and reconnect. For PS/2 devices, you will need to restart the computer to check if the devices work. For USB devices, try connecting to different USB ports.
Next step, try using a different keyboard and mouse (that work on another computer (stick to USB or PS/2 to match the current pair)). Try a wired set if the problem is with a wireless pair. If those work, continue diagnostics on the wireless keyboard and mouse. Check if the mouse and keyboard work on another computer. If they don't work with another computer, replace them.
If another USB keyboard and mouse pair don't work in any port, your USB ports may have failed. Check if even one port works enough to access the Device Manager. (Start > Control Panel > Hardware and Sound > Device Manager (Win7); similar directions in other versions of Windows) Check for a problem with the drivers (For USB ports, scroll down to the USB drivers and look for a triangle with a yellow exclamation point or red x). Try to update the driver or roll it back. If that doesn't help and one USB port works, a USB hub may solve the problem.
Otherwise if the USB or PS/2 ports do not work with any devices and the driver fix doesn't work, then I'd suspect a problem with the ports on the motherboard. Replace the motherboard/computer.
I hope this helps.
2helpful
2answers
I just bought a Missil MP2000 8GB mp3 player and my computer does not seem to recognize it. i'm using windows 7 and my usb ports still work for other devices, yet my computer doesn't even register...
Ok go to setting Mode on the device. hit the '<< or >>' until you see it then select it with the play button >''
Once in there go down to "Online Mode", once in that menu, select "Normal only".
You are done, device should pick up as a USB right away.
This was given to my daughter as a gift. she wasn't given the disk or whatever it takes to connect to my pc. yes i have the cord that is not what I mean I need the download information. also it needs...
The unit doesn't come with any disk. factory settings can be done on the mp3 player itself. Soft reset is on the back of the unit, just use a paper clip to reset.
Your computer should automatically detect the device as a 'removable disk' drive under 'my computer' after you plug it in. if not, it might be on MTP mode, In the device menu, go to 'SETUP' > System > USB Mode, make sure you have it on MSC. Some computers are missing MTP (because you dont use Windows Media Player), then reconnect it, computer should read it correctly.
3helpful
2answers
There is somethig seriously wrong with my PC. It was attacked by some computer viruses
You can try to run a full virus scan in Safe Mode. To access it, you will either press F8, or Del (depends on what key was designed on your computer to access the Advanced Boot Options), after getting the Advanced Boot Options, select Safe Mode an press Enter key.
If your antivirus software cannot detect any virus, it was either not updated or was disabled by the virus. You need to contact your antivirus company to get help with manual virus deletion.
However, if you don't have any antivirus installed I suggest to just wipe everything off from the harddrive and start from factory settings.
Hope this helps.
1helpful
3answers
I have a samsung GT-S5600V ive installed the software for it 'USB cable' and 'Samsung new PC studio' and ive connected my phone to the computer through the USB cable and its not searching...
HI there,
I've personally gone through this circle...ugh.
First - Reboot your computer, and your cellphone. Turn them both completely off, and back on.
If that doesn't solve it,
Second - UNinstall everything to do with your phone. Drivers/Software/Etc. Once that's done, Reboot your computer. Now reinstall the drivers/software/etc, and when that's finished, plug your phone in, let windows find and install what it needs to.
If THAT doesn't work,
Sometimes windows installs your phone as a modem, and then as a usb disk. It may be possible that you machine recognizes the modem first and runs a process to coincide with that. FInd that process and kill it, and you should be good to go!
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Marvin
Marvin
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
