Question about Rowenta Commercial Garment Steamer - White
I have a rowenta commercial steamer IS-8100, I used it last evening, and it is leaking water where the tank meets the base, I don't know what to do can you please help
Posted by cashck4 on
Diane Haggart
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
Look at the bottem the screw thing may have come loose
Posted on Sep 08, 2011
How to clean a Rowenta steamer
WHen cold tilt over sink and empty and rince every 3-5 uses depending on how much you use it. Water sitting in the tank gets moldy and bad, rinse tank and use Britta type filtered water only.
Jun 18, 2014 | Rowenta Commercial Garment Steamer - White
Need Replacement Support Pole for Rowenta Commercial Steamer
According to eReplacementparts the DC0084 part you're looking for is not available for retail sale. They do however inform that that the part is avaiable for sale via Rowenta Service Centers. You can find a list of these Rowenta Service Repair Centers by state, here. I hope this helps & good luck!
Nov 07, 2013 | Rowenta Irons
My rowenta steamer is not producing steam but tubing getting hot when I turn on steamer. Suggestions?
see this causes and fix it. God bless you
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber .
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat .
If the iron does not spray properly, inspect and clean the nozzle.
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.
Feb 03, 2013 | Rowenta Commercial Garment Steamer - White
I have the vertical commercial steamer model IS 8100. Machine lights up, no steam. The cord doesn't even get hot. I've tried to demineralize it by allowing vinegar to sit in the well of the base. Thanks...
My unit did the same thing. There is a temperature fuse attached to the heating chamber. If the unit overheats it will blow this fuse. It is not re-setable and must be replaced. Radio Shack carries these items.
Check your chamber for crude. Mine was pretty bad and I ended up filling it up with white vinegar over night. If you can get it to work, boil a solution of 1/4 white vinegar and DISTILLED water. Let it run through a whole tank of it and then run it with just DISTILLED water until you don't smell vinegar anymore. Do this every few months with heavy use.
Jan 10, 2011 | Rowenta IS8100 Iron
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
On and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Jun 10, 2009 | Rowenta Commercial Garment Steamer - White
IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - White Logo
620 people viewed this question
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
