Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH Logo
Question about Encore 802.11G WIRELESS LAN ROUTER W/4-PORT SWITCH
New password wifi
Posted by markanthonyj on
Anonymous
    Scholar:
  • 114 Answers
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Posted on Sep 08, 2011
ONN tablet Google locked
If it is connected to WIFI,
Go to settings on your phone, go to connectivity, go to WiFi and then reset your password from there. If your Tablet asks you for a new password, then enter 12345 because that is the default WiFi password for all Android devices. After that, you can enter a new password and re-create your WiFi password.
How do I reset my password on Vodacom WiFi router please?
factory reset google nest wifi router In the address bar of your browser, type 192.168.1.1.
It will ask you to reset or update your password when you first log in.
Replace your old password with your new one and log in again.
Enter the vodafone password.
Select Expert mode.
After that, there's WiFi on the banner.
Select the General WiFi Settings option.
1helpful
New WIFi house hub. Automatic WiFi connection process has not worked despite a good WiFi signal.Why ?
You should be able to do a factory reset. This will restore the default password, and the default permissions. Your manual or the online manual will tell you how to do a factory reset and the default password.
2helpful
I reset my wifi password and can't connect
First: Your WiFi password is located under the WiFi device.
Second: on the WiFi connection status (right bottom corner of your screen), click it and click on your WiFi name (SSID), key-in the password in the box.
I have a powerbook G4 and just hooked up a wifi motem but it asks for a password I don't know
If the wifi modem is a new type, just push a button at the modem and then try to connect form MAC. Password is automatically transferred.
If you have an older wifi modem, you will need to know the password by login into the wifi modem.
1helpful
Trying to connect to wifi with new sumvision voyager, how to get a password?
You either need to have your own Wifi Hotspot or ask the password from the owner of the Wifi Hotspot that you want to connect to.. not everything is free.. Hope this help.. good luck.. :)
How to find ur wifi password
The D-link support desk can help with the default password to the unit, but can not tell you what your wifi password is. If you have a device on wireless you can go to the wifi adapter and usually check a box that says "show password in text". If that is not an option, log into the D-link and change the wifi password to something you know and can remember.
Note: changing the wifi password will break the wireless connection to any existing thing that uses wifi. You will have to go to each device and change them to the new password.
92helpful
8answers
Master password for wifi
I need master password of wifi
Top Encore Computers & Internet Experts
Steve
Are you an Encore Computer and Internet Expert? Answer questions, earn points and help others
