Samsung 24 in. DB5710DT Stainless Steel Built-in Dishwasher Logo
Posted on Sep 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a new stainless steel Samsung dishwasher. It doesn't seem to be drying properly. Dishes and dishwasher still very wet after cycle is completed.
Anonymous
Level 3:
Genius:
  • Master 1,456 Answers
  • Posted on Sep 07, 2011
Anonymous
Master
Level 3:
Genius:
Answers
1456
Questions
0
Helped
475576
Points
4013
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
1helpful
Dishes not dry after wash cycle
Hello uno203 - Hi - If the unit is not drying nor cleaning properly, there are two main things to check first. Is the incoming water temperature at least 120F (49C)? If not, I strongly suggest that the temperature be adjusted on your water heater. Are you using rinse aid? Use a rinse agent to increase drying performance and using Sanitize or Air Dry Off mode also helps improve drying. If any proves to be ineffective, contact a professional to move forward accurately. Unit may have an issue with the heating element or a communication problem with the board not responding.
New dishwasher...The Rinse Aid doesn't seem to be putting out any liquid. (How is it supposed to work?) Plus, dishes don't seem to be coming out as clean as expected. In your opinion what is the...
You won't see any liquid it comes out and gets rinsed off during the last wash cycle.As for detergant I think your best bet is to use the tablets. Like the three and one "Finnish " Hope this helps.
Dishes are wet after wash. Appears drying cycle is not working.
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker
Dishwasher is not properly drying. The rinse agent dispenser has been filled but dishes are still very wet at end of the cycle.
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Elextrolux dishlex DX 302 - not cleaning dishes properly and dishes still wet after drying
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
2helpful
2answers
Dishes are ALWAYS WET!!!
If the dishes are made of plastic they will be wet , they don't retain heat when in the drying cycle!
2answers
Not drying
These dishwashers have no heater for drying dishes. It has a fan to circulate warm air. It is very important that your water temp is at least 120 degrees. It is the combination of hot water and air circulating that dries dishes.
4helpful
4answers
Dishwasher not drying
Same problem here. I read the manual very carefully. "OptiDry", "ExtraDry", "EcoDry", "condensation drying" -- lots of fancy words to cover the simple fact -- they DO NOT DRY the dishes. There is no heating element. I wish they would just state this up-front. Air drying the dishes for 24 hours after each wash is not workable for most users...
LG LDF6810 Drying Cycle?
This is normal and the amount of water can depend on how soon after the cycle has finished as to how much condensation is on the walls.
Top Samsung Dishwashers Experts
vince
Daniel Blask
Daniel Blask
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
