Hitachi DZ-MV730A DVD Camcorder Logo
Anonymous Posted on Sep 07, 2011
I cannot open or eject the digital disc? what can be the wrong?.
Anonymous
Level 1:
Scholar:
New Friend:
  • Contributor 36 Answers
  • Posted on Sep 07, 2011
Anonymous
Contributor
Level 1:
Scholar:
New Friend:
Answers
36
Questions
Helped
4854
Points
63
The eject button, the spring, or the piece of plastic that pushes it out.
  • Anonymous Sep 08, 2011
    I am sorry, but YOU HAVE NOT SOLVED MY PROBLEM!. Credit my payment Please......
1helpful
Panasonic dvd video camcorder VDR-M55PP
system malfunction, put a soft reset on the camcorder.
1helpful
How can I unlock Samsung HT-H4500R
1) Turn on the player with no disc in the tray.
2) Open then close the tray, wait to see the No-Disc Message
in the top Left Corner.
3) Now press the REPEAT button on the remote, followed by a
five digit code. eg. 57538 if you have a region 2 player.
4) When it works a 2 (your current region) will appear in
the top left corner.
5) Press 9 to make it region less.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all
regions of DVD/BD Disc.
Here is a list of all the region codes:
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
Can't reject disc from curtis tvdvd combo
Hello
Just open the top cover, and try to eject the disc inside.
2answers
My sony dvp sr200p cannot eject the disk inside. i tried all the 4-digit code but i failed.
From www.sony.com
Unable to eject a disc.Solution
Follow the steps below to troubleshoot this issue.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online through the Manuals/Specs/Warranty link on this page.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
    NOTE: This step may not apply to all models.DISC1 is not available on all DVD players.
1helpful
Opens and closes repeatedly
hello,
The most common reason for the player opening and closing itself is a bad drive. The following website sells the drives and does installs:
store.richspsxparts.com/wiiredvddr
This drive should fix any reading issues you are having with your player, or issues inserting your games or ejecting them (or lack thereof). This is the entire DVD drive assembly mechanism replacement for your player including a new laser. If your discs are not ejecting, or you cannot insert a disc -- or you can insert a disc but it will not load, this is what you need to get your player going again!
Hope this helps...
10helpful
PS3 Won't Take Disc!
Hi, I think it was me who had helped you before. I will be glad to help again. Ok, first you have to tear apart your PS3 (just like when you cleaned it). Now looking at the rollers and "dogs" make sure that they are closed and not open all the way like when a disc is in it. Look at the flap on the top too make sure it opens and closes freely. Next, PLEASE BE CAREFUL!! Plug your PS3 in and try to hit the eject button, if it is reset and ready for a disc it will beep twice when you hit the eject button without a disc in it. Place the top back on the he DVD drive and try to insert a disc. At this point it should take it. If not then try hitting the eject again. Once the PS3 resets and takes and ejects discs again, then you can put it back together.
DVD in the wrong way; won't eject
Apart from taking it apart! or forcing the disc tray out "DON'T" !!! try switching off at mains holding eject button continuosly pushed in and put mains back on, sometimes this causes a full "re-boot sequence" which from experiance and several attempts, does throw me the tray open!
1helpful
2answers
Stuck dvd disc.
Hi there
Page 80 in the instruction manual tells you how to do this.
In case you don't have a manual, do the following:
While the unit is off, press and hold the stop key (shown on the unit as a button with a small black square on it) for about 5 seconds. It may take longer to eject depending on the disc.
Hope this helps
Top Hitachi Video Cameras Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
