First downloadand install Pheonix. NokiaPhoenix Service Software 2011 -Download secondly Download flash file from this link Nokiaflash file and install it to C / programmefiles/pheonix..after finished thisinstallation open pheonix Inside the interfaceat the> left top File" click there and choose "open file"andthen select the approprait Product type i.e"which is written inthe back banel inside the battery of every Nokia(Type RM-000).Afterdoingthis again at the left top count from "File"1..2..3..the 4th oneis"Flashing" press there when you click there you'll seethreei con just select the "Firmware Update" again you'll seeanother interface.Look at the product code there should be blank and putyour"mouse tool" at the straight end from the "Product Code"thereis a Botton and choose the code which is written in the back sideof your phone.e.g CODE:0000000.if the same code does not found, justtake one.After this you can see "Dead phone USB flashing"clickthat box.Now this is the last stage... Connect your phone with the USBtoyour PC and let the driver install ...wait for a moment.(If yourphone working).Lastly after just finished (In case your phone isDead,unable to switch on in normal mode start from here) Connect thephone to pc without powering...insert good battery and Click the "Referbish"afte rthis, a message will prompt you "press power botton"press it and wait untill the phone will Restart automatically
You need to flash it for what purpose,?
You need to flash it to reset to original settings or security lock hang purpose?
You can flash using software for that purpose,If you need to unlock it from Network lock using Flash method?
You can use the Unlock code,that is best than software flash,.Get the Unlock code from here
Prounlocking and unlock it from Network Lock.Then you can use any GSM Network Sim card in the Phone....It's best for Unlock.....you can use the Flash software for De-brand the Phone also Removing Logo,Settings etc from previous provider...after unlock it de-brand will be Done.
Just install nokia pc suite
SOURCE: i forget my mobile nokia
Hi If you changed it and
forgot the security code please contacts your device dealer. They will provide
you the default security code so that you can use your phone. This security lock
prevents thieves from being able to make use of stolen handsets that is why it
can only be unlocked by authorized device dealers. Thank You
The default Security code is 12345.
