Question about Sony Handycam CCD-TRV608 Camcorder
My cam wont play or fast forward,, it will rewind for but just for a second then it does the same thing as when you try to play it,,, it starts beeping and then the eject icon appears on the screen ,if you could assist me with the issue id be grateful thank you
Posted by cold_fingert on
Eduardo Romero
    Scholar:
    New Friend:
  • 36 Answers
Sounds like it may have gotten wet or it's just wear and tear. You'd have to open it up and fix it manually. maibe some sircuits are bloked. If it was in a hot place some small plastic may have melted on to the mother board. Could be that the ruber under the butons are just worn out. If you're sure it should work try to be patient. press a button and just wait 5min. It may just be slow cause it's old.
Posted on Sep 07, 2011
oladeji sodiq
    New Friend:
  • 47 Answers
The problem is from the mechanism,these are some things you can try on your own
1)when the tape is already inside the mechanism and it have finished loading try to nock gently to make the tape load properly
2)if that do not solve the problem you have to loose the camera completely,then you change the capstan
How do i get a sony microcassette transcriber m-2000 to play/rewind/fast forward continuously?
Probably has a bad sensor belt (small belt attached to silver and black reflective wheel).
Aug 07, 2014 | Sony M-2000 MicroCassette Transcriber...
The VCR shuts off after just a few seconds of playing or rewinding or fast forwarding. The tape goes in, and when you push play (or any direction), the unit will try and play it and then it will shut the...
There is a part that is called an idler wheel assembly that is critical for play, rewind, and fast forward, and may have stopped working. The second possibility is that the drive belt that runs the idler assembly has broken or come off.
Jan 01, 2011 | Philips DVDR3435V/37 DVD Recorder/VCR
The dictaphone wont rewind or fast forward and makes a bleeping noise
Does the tape move when you press rewind or fast forward.
If the tape moves for a few seconds then bleeps it sound like a sensor problem.
If it only bleeps when the rewind and fast forward are pressed and the play is ok it sounds like the actuator motor is faulty,this motor enables the rewind and fast forward.
Hope this helps.
Dec 07, 2010 | Dictaphone 1740 Desktop Cassette...
Teac HDR2500T Fast Forward/Rewind problem: It
easy, download the software update from the teac website- had the same problem myself
Jan 10, 2010 | Televison & Video
Does not play. will rewind & fast forward
Its most likely the cam gear. Any sony dealer can replace the gear.
Jan 07, 2009 | Sony BM-87DST Desktop Cassette Transcriber...
VCR sv 670 wont play or fast forward tapes.
Open the bottom Cover, and check the belts.
Nov 29, 2008 | Samsung SV3000W VHS VCR
Won`t Rewind
Do you still have the remote control? Try with the remote. If this works, the button of the camera is broken and have to be replace by a qualified technician. Good luck!
Sep 27, 2008 | Sony Handycam CCD-TR517 Camcorder
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Sony Handycam CCD-TRV608 Camcorder Logo
70 people viewed this question
Top Sony Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Larry Stiles
Larry Stiles
Al Rush
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
