Question about Casio Parts Cash Register PC Desktop
Hi There my SAM4S is showing PEA on the screen. All the buttons are locked also. I have unplugged and it doesn't change anything? Can you help?
Posted by maya524 on
Sangerwest
    New Friend:
I have a SAM4s register. When it read "PEA" all I did was pull the receipt paper. It seemed to be jammed. Worked for me.
Posted on Jan 09, 2012
Electroboy
  • Casio Master
  • 1,879 Answers
Hi. Which model number?
Posted on Sep 07, 2011
PEA is on the screen and no keys work
stuck splash screen Cash Registers & POS Equipment ...
www.fixya.com > Forum > Tags > stuck splash screen
Ask your stuck splash screen cash register and pos equipment questions. ... ...screen displays PE, machine stops working Register tape won't feed, turning it off then back on ... the register is stuck and is displaying PEA Perfom a master reset ... Screenstuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
delay stuck Cash Registers & POS Equipment Questions ...
www.fixya.com > Forum > Tags > delay stuck
Cash Registers & POS Equipment delay stuck questions and answers. Ask your delay stuck ... Also if that doesn't work and its a dual com, make sure its set to dial. coppy ... Ad ... the register is stuck and is displaying PEA Perfom a master reset ...Screen stuck on x2/z2 turn the key and it stays on x2/z2 no matter key position.
Hi There my SAM4S is showing PEA on the screen. All the ...
Nov 26, 2015 | Retail Supplies
Register is saying Paper end. I have replaced it and it still will not work and reads PEA
Make sure you have paper running in the receipt and journal side. Make sure paper is correct width. Try pressing the clear button to clear the error.
Oct 07, 2015 | Sam4s ER-5240M
Screen says closed we can't get it to change
You need to log the clerk back in. try pressing 1, then clerk button.
Apr 07, 2014 | Sam4s Samsung Er-290 Cash Register
The register display Says PEA and does not do anything
TUrn you key to pgm and press subtotal then switch on the machine while depressing sub/total button. good luck
Mar 05, 2014 | Sam4s Samsung ER-380 Cash Register
Samsung er-5115 sam4s cash register is locked up and read PP00. Unplugging does not do anything. None of the keys respond.
Your printer is stuck.1 open the printer cover 2Pull out he ribbon 3 plug your machine, that should work
Sep 18, 2013 | Sam4s Samsung Er-5115ii Cash Re
My Insignia TV has a blue screen with parental cotrol the problem is I don't have a Control to pres display how can I unlock it???? HELP:(
Hello
When an Insignia TV is locked, it keeps you from watching all of your channels by only displaying a black screen. Insignia TVs are locked from a single button command on the remote control, so it is easy for you to lock the TV by accident. Since Insignia TVs can be locked so easily, it's important to know how to undo this command and unlock the TV yourself. So, unlock your Insignia TV with the push of a button and once again enjoy watching your favorite programs.
· Find the lock button on the Insignia remote control. The lock button is located on the third column from the left on the second row from the top of the remote.
·Stand within operating range of the Insignia TV, then aim the remote at the TV's receiver and press the "Lock" button on the remote control.
· Aim the remote at the TV and press the channel buttons to make sure the TV is unlocked. When the TV is locked, it shows a black screen and does not allow you to view anything else. If the screen remains black, press the "Lock" button again. If this doesn't work, change the batteries in the remote and start over at step
OK
Sep 17, 2011 | Insignia NS- 27" TV27 TV
PEA is the screen...All the are locked and even if i pull the plug out it still comes up.... How do i get rid of it??
hi. Sorry, I don't understand. Does the display only show 'PEA'? I have never had this. Please let me know the model number.
Mark
Apr 17, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
1,867 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Marvin
Marvin
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
