Belkin Basic Wireless Router Logo
Question about Belkin Basic Wireless Router
I looked on line to get a password, but it won't accept it. I have an I pad that works everywhere else.
Posted by locket52 on
Anonymous
    Scholar:
  • 114 Answers
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Posted on Sep 08, 2011
My epson printer won't accept my complete password
May be its a technical fault. Or you can try to change the password. I suggest contacting Epson printer technician through free live chat. They fix your issue on FREE Live Chat.
Electric blanket won't heat
Take the help of your mattress pad company or look into instruction manual. Do not operate it unless you are familiar with it. You should call the customer care to know how to operate.
Jack from Coriumdirect Mattress pads
My Child Pad won't come on. My dad thinks it's something to do with the screen but I'm not so sure. Why won't it come on and how can I fix it?
I think I may be able to help you. So the same prob;e came with my childpad. Just remember as long as it does not work have the password with you. Because my works now but I forgot the password. So I opened the back blue thing. And then I figured that the charging thing was to loose. So, I just have to make it so that the charger won't come out, so some how my dad make it tighter. But I think that might be the problem with yours as well. If you have a solution to my problem (forgot password) please email me at [email protected] Thanks!! And I hope it helped in some way :)
1helpful
2answers
I have a thomson twg850 router but it won't accept my password, what do i do
Hello you might have to reset it and set it up again.
TWG850-4U Default IP: 192.168.0.1
TWG850-4U Default Password: admin
TWG850-4U Default Username:blank
Here is a guide:
http://compnetworking.about.com/od/homenetworking/ht/routerconfigure.htm
Good luck
1helpful
Encryption accessibility
I met the same trouble, i just reset acer password by the following steps,
Step1.Download Smartkey Windows Password Recovery from recoverlostpassword.com anddecompress it on that PC. There is a .ISO file. Burn the .ISO file to CD or USBFlash Driver.Step2.Get out the newly created CDor USB Flash Driver and insert it to the locked computer.Step3. Re-boot the locked computerand then follow the process of instructions. Just after a few steps, the oldpassword will be removed.It can recover all Windows version.
Pc won't accept printer via usb connection
So why won't it accept the printer? Is the printer and your operating system on the computer compatible? Did you install the printer and drivers? Are you sure the USB Port works?
Have you tried a different USB Port?
Click Start/Control Panel and look for Printers. Open it and make sure you don't have more than one instance of the printer installed. If you do, then you're confusing the computer. You can also check to see if more than one of the same printer is installed by opening a word document, then click File, then Print, and when the print window opens up click the Down Arrow on the line that shows the printer name. This will show you all other installed printers.
Iregistered as [email protected] with maggiemae as password and it is not being accepted??????
Hello.
Are you just trying to register a paypal account? You should think of a more secured password or else paypal won't accept it. Add numbers to your password and don't use your name as a password. It is for your own security too.
Top Belkin Computers & Internet Experts
Donivan Wise
Mike
Steve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
