We have a jbl marine stereo from 2006. It will not change channels nor do any of the other functions work except voluime and cd sometimes. Have pushed reset button
Question edited for clarity, proper 'make model (what it is)'.
I can't find a manual, but they have a common theme. Remove the faceplate and press the Reset Button, then clean the contacts both sides with electrical switch cleaner or Isopropyl Alcohol.
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
JBL is at best a low quality marine grade brand of stereo. It is now garbage. I have worked on hot tub stereos for many years, PolyPlannar is the only one that is any good. If it was bought 30 days ago, where's your warranty?
yes i am a repair shop and i have had nothing but problems out of those units you might want to look into a different unit boss marine is a good choice
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
Hi I have a spa with the MR4 sterio and i want to remove it can you help as i am unable to remove it , the front comes of and i can not see how the rest comes out .
