Posted on Sep 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is error 5200 on a Canon i860 Printer. I cannot locate my manual.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Cannon Master 102,366 Answers
  • Posted on Sep 14, 2011
Cannon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441283
Points
622693
Are you certain it's 5200 and not 2500?
You can download the manual and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/i_series/i860_series
2answers
How to Fix Canon Printer Error 5200 ?
Canon Printer Error 5200 may occur if the ink level in your printer is low or if you have a defective ink cartridge. Follow the steps to fix Canon printer 5200 Error code:
·Refill your cartridges/Ink tank
·Clean printer cartridge
·Factory reset printer
Find here the more canon printer error codes and their solutions.
2answers
What is error code 5200 on a mp830 all in one cannon printer mean?
Canon printer error code 5200 is a technological malfunction that stops printing of a canon printer. The error is registered on the screen when the temperature of the ink cartridge is high. There are no concentrations of ink present on the ink cartridges. The print head of the printer is also heated by a temperature rise resulting in an error code of 5200. Canon Printer Error 5200 Few troubleshooting steps are explained below. These troubleshooting steps are so basic that they can be performed by anybody with enough guidance. But if, in any case, someone is unable to comprehend these troubleshooting acts, assistance from trained experts is needed.
Canon printer error code 5200 is largely due to cartridge problems. This can be due to a low amount of ink in your cartridge, a faulty cartridge, or maybe there are some flaws with the logic board of your printer. We realize that Canon printers are designed to be printed in black, even if the Black cartridge is empty, using colors in the ink cartridge. Thus, if you see a mistake of 5200 in the Canon printer, the printer cartridges are either empty or near to empty. Now that you know the root of the error, let's talk about the solutions.
Our Services: You may find that the Canon printer error code 5200 has been deleted after the above information has been completed. But if you still get the same error code on your computer screen when printing, you can contact Our Printer Error Specialist now.
Check given blog.
34helpful
4answers
Error 5200
Error 5200 is a printhead temperature error, sounds like you need a new printhead. The part number is printed on the side of the printhead. it's a QY6 number
4helpful
2answers
Canon i860 error code 5200?
5200 is a printhead temperature error, defective printhead You need a new printhead,
QY6-0049-000 around $40.00
1helpful
Canon i860 printer not working
The error code says that your printhead is bad and needs to be replaced. QY6-0049-000 around $40.00
3helpful
2answers
I've been trying to print a powerpoint presentation and I keep getting a printer error 5200. I don't see what that means in the manual. Can you help me with this? Audrey
Error 5200 is a print head temperature rise error according to the Service Manual. The suggested replacement parts are the print head and/or the logic board - Expensive. It's supposed to be accompanied by 8 alternate cycles of the orange and green lights.
Page 1-5 of the Service Manual.
excessive cleaning cycles can cause heat buildup, but it should cool between jobs with enough time.
Canon i860
Have a look at the yellow cartridge. I have had trouble with inks leaking into each other...most noticeable in the yellow. I have no solution...perhaps the printhead is a piece of ****...works well when it works.
Canon i860
Print head temperature rise [5200]
I would assume that the cleaning efforts resulted in oveheating the print heads.
Please ensure that you have sufficient ink, as ink acts as a lubricant for the heads.If you try to use them while empty it is equivalent to driving a car without oil.
Take your time..
Verify ink is in all cartridges.
Remove paper jam
let the printer cool off (heads)
Chances are the head alignment is not necessary and you are low on one of the inks...
Try this test program (Page) to isolate low colors...
http://www2.clicshop.com/Stores/metawatch2/Files/metawatchprintertestpage.pdf
Top Cannon Office Equipment & Supplies Experts
NOEL
NOEL
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
