Question about eMachines T3406 PC Desktop
What keys do i use to do recvoery to factory setting like new
Posted by david michie on
  • 1 more comment
  • david michie Feb 06, 2012
    is there a key to do that fii or something
    is there a key that i can hit to recovery
    can you recovery without the cd am there a key that you can use
Curtis Sewell
  • 7,482 Answers
Hi michieday368...
To set you computer back to factory fresh settings you will need to format the hard drive and re-install the operating system and the drivers.
You will need to have the CD's that either you made when you got your computer or if you were lucky you got the CD's that the factory furnished with the computer at the time you bought it.
If you do not have the CD/DVD's that came with your machine then you will need to go to the Manufacturer's website and buy the Restore CD's or DVD's.
If the machine is too old, your only option is to check on ebay...
You may get lucky, and someone or maybe a company will have you CD's or DVD's available.
1.Format the hard drive:
You do this by double left clicking on "My Computer",then double left click the main drive (normally C drive).
When the window pops open, you will choose "Format"
Keep in mind that once you format your hard drive you will loose all your files,programs,pictures,etc that you installed since the computer was new. So make your back up on a portable hard drive,thumb drive,etc.
Please take time to rate me
Posted on Sep 07, 2011
How do i start a 2002 chevy without keys
call your Chevy dealer they can get new set of keys, by using the VIN # number of the vehicle,,it won't be cheap ,,, you
will have to prove owner ship....the cheaper way will be get a new
cylinder switch,, from you local auto parts,,, the cylinder switch
come with a new set of keys.......good luck.....
Mar 02, 2015 | 2002 Chevy Astro - Passenger van, with...
How do you reset the blackberry 9360
Restore factory default settings
When you restore the factory default settings, all personal settings are reset. Follow these instructions to restore the factory default settings.
All phone data will be deleted. Data on your SIM isn't deleted.
1. Find "Security Wipe"
Press the Menu key twice.
Scroll to Options and press the Navigation key.
Scroll to Security and press the Navigation key.
Scroll to Security Wipe and press the Navigation key.
2. Restore factory default settings
Highlight Emails, Contacts, etc., User Installed Applications or Media Card and press the Navigation key.
When the box next to the menu item is ticked (V), the selected data will be deleted.
Highlight the field at the bottom of the display and key in blackberry
Scroll to Wipe and press the Navigation key to restore the factory default settings.
Follow the instructions on the display
Oct 15, 2014 | Cell Phones
NOT WORKING, SAYS PUT IN NEW CODE
1. it might want you to key in any new code. try key in any new code.
if not...
2.RESET your routers by push the small pin hole button usually at the rear of the router. do this about 3 to 5 seconds with power on, it will revert to factory default then you can set the code . usually factory setting; username: admin, password: admin
Oct 27, 2013 | Computers & Internet
Need to factory reset windows xp without disk
Restoring a computer to its original factory settings should be the last ditch effort in attempting to save a system that has been corrupted by viruses or defective programs. In the best case scenario, one would use the system restore CD that ships with new computers but often this CD is lost or the computer was purchased used. In this case, a factory settings restoration can still be performed by using the computer's "Advanced Boot" menu.
Restart the computer. Press the "F8" key after the computer reboots but before the "Windows" logo appears on the screen. You should now see the "Advanced Boot" menu. Scroll down through the menu options using the down arrow key. Stop when "Repair Your Computer" is highlighted and hit the "Enter" key. Select the language you wish to use and press the "Enter" key. Type in the computer's administrator ID and password. Press the "Enter" key. Scroll through the options using the down arrow key. Choose "Restore (name of computer manufacturer) Settings." Press the "Enter" key. Choose "Yes" when asked if you want to reformat the hard drive. Press the "Enter" key to begin the reformatting process. The process takes a few minutes, so be patient. Do not turn off the computer or attempt to stop the process after it has begun, or this may result in major damage to the hard drive. Choose "Finish" and press the "Enter" key to restart the computer. The computer will restart with the original factory settings.
Feb 08, 2013 | E-Machines (T2958) PC Desktop
Factory restore without cd
A name of the computer and operating system would be nice ? so some can provide with an appropriate answer you see different computers and operating systems all have different ways of doing a system restore to factory settings ?
Hope this helps.
Nov 21, 2012 | Computers & Internet
Can i keep new windows 8 pro after fresh fujitsu factory settings
Buy Windows 8 Activation Key 64bit 32bit
http://www.Genuinewindowkey.com/
of course, the best place to buy a key is ms. i purchased years from ms online store. however, this time, i'd like to share one special experience on http://www.Genuinewindowkey.com/ .
i visit my forum everyday. one day, i found a piece of recommendation from another guy. so i visited this site.
at the beginning, i'm quite skeptical at them. the price is too low.
then i sent many questions to them.
out of my expectation, they replied to me very soon. each question was answered.
at that time, i planned to try the new Windows 10 Education Product Key.
long story short, i purchased a key from them, received it and download links(32bit&64bit) in about one hour. i need 64. and, more important, the key works at the first try.
i sent much feedback to them. in one word, i'm very satisfied with this purchase, and i think, i should pass words to you.
I tried to root my HTC evo Comes up wrong image or no image Found then is comes up update Failed newer version
what is your hboot version ?? is it 1.02 0.92 0.88 0.83 need more info what android ver you running 2.1 2.2 is it all factory as of now your hboot version and your recvoery version 2e or 3e recovery lmk so i can help thaksk
May 09, 2011 | HTC Cell Phones
How do you restore to factory setting
Press F2 during the boot to get to Cmos. Once in Cmos go to the Exit tab and locate the line for Set to Factory Defaults and chose it. Your system will be back to the factory spec after a new boot. Some systems have diffrent Function keys to get into Cmos so watch the boot screen for the correct key to press. Most are the F2. Good luck!
Jun 06, 2010 | Toshiba Satellite A100-S8111TD Notebook
SETUP UTILITY PASSWORD ????
it looks like your computer is hacked by someone else,you can reset the password even if you didn't know what it is,windows password recvoery 6.0 can help you,
May 20, 2010 | HP Pavilion dv9000z Notebook
I have windows 7 when I try ro restore I get error message 0x800x70005
This error comes because there are bad sectors in your harddrive.
For that you have to first fix and recovers those bad sectors.
For that insert windows disk or recovery disk into rom then when you power up the computer press F1 or F2 or del or ALT+F2 key to enter in bios then go to boot menu and set first boot device as cd/dvd rom then save settings and exit.
Then it boot with that disk then follow the procedure and enter in recvoery console mode.
Then type in prompt "chkdsk /r" without "" then press "y" then it fix and recovers all bad sectors.Then you can restore it easily.
Let me know if you need further assistance.
Thanks for using FixYa.
Mar 16, 2010 | Microsoft Windows XP Home Edition
eMachines T3406  PC Desktop Logo
107 people viewed this question
Top eMachines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
