VOX Amplification VOX VT100 Valvetronix 100 Watt Tube Amp Logo
Cody Brown Posted on Sep 07, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a reset button for a Vox Valvetronix 100watt amp AD100VT, if so where is it located?
Fred Yearian
Level 3:
  • VOX Master 5,603 Answers
  • Posted on Sep 08, 2011
Fred Yearian
VOX Master
Level 3:
Answers
5603
Questions
Helped
2250429
Points
16163
There is NO "reset" button.
Is it possible to lower the VOX VT50 transfo outgoing voltage?
bulbs have tolerance, that means it can work with + or - 6.3v just use the 7.6v which a diffrence of 1.is ok for it to work.
Vox vt40 factory reset
Consider reading the Manual for this amp, it explains how to reset to factory with the VFS5 footpedal. Or with the power off ..hold down CH1 & CH4 then turn power on.. when the Bank & Channel leds start blinking.. then release the Channel buttons. Next press the Tap switch ... the bank & channel leds will change from blinking to lit. with in a few seconds it will enter preset mode.
Vox vt40+
that is because it is two different output channels. eventually you will blow the speaker or your amp. It wasn't designed to handle the impedance of an external speaker through the stereo
headphone jack. Are you sure that your speaker is hooked up or plugged in?
Vox Tonelab LE. One of black buttons on my unit has got damaged and pushed under the metal casing so it is permanently pushed down. (Used to set preset values). Has anyone got a procedure for taking this...
Hi it could be that the switch has failed if it is something you are not confident with ask an independent electronics repair shop for some help. Sorry I cannot help more but I cannot see how the switch can be seized in the on (Depressed) position.
Vox vt120+ cutting out and then coming back on. even when the jack lead is not in the jack input. the fuses all seem ok.
i live in mexico and musics stores here sucks I'm an engineer and y started experimenting i think its an IC the TAS5615 im about to order it but does anyone know for sure what it could be??
1helpful
I have a vt50 and it has an extremely loud buzz when I turn it on with nothing plugged in. It sounds like the speaker is going to blow. I don't know what's wrong.
Yes you could blow the speaker. There is either a problem in the power supply or possibly the power amp chip has shorted to one of the power rails. Some of the vox stuff uses th LM3886 chip as the power amp. While these are supposedly protected, they can go bad. Download A schematic that MIGHT be close to your unit... it is for the VT30 but probably is similar:
http://elektrotanya.com/vox_ad15-30vt_sch.pdf/download.html
Scroll down to "Get Manual" and click on it to download the schematic. Do this test: Adjust the power level control. IF it doesn't vary the level significantly, then check the voltage across the speaker... IF it isn't less than 1 volt DC (bias) replace the LM3886 chip. Use thermal grease and any insulators they are using. Chip about $8 from Digikey.com. Note these come with two different pre-bent leads... make sure to get right ones. IF the output bias is with 1 volt DC of ground, check for bad filter caps and rectifiers.
Top VOX Music Experts
ADMIN Andrew
ADMIN Andrew
Arun Deep
MJ MJMJ
MJ MJMJ
Level 1 Expert
Are you a VOX Music Expert? Answer questions, earn points and help others
