HP.com
see your manuals and what the blink codes mean.
each PC has PDF manual that covers that.
blink codes are BIOS warnings.
to tell you what catastrophic failure happend
like low power
bad memory
processor dead
GPU dead.
and more, some have 12 errors possible (newer)
if the BIOS screens are dead, its lost power.
or one of the above.
SOURCE: cq61 notebook will power on but not boot. the caps
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
SOURCE: nc6220 PC Notebook won't boot up
Motherboard. Your best bet is to purchase another computer. If you can however get the motherboard at a cheap price, then go ahead and change it. I would check ebay first.
SOURCE: I am having HP
open up the on screen keyboard in accessories>>ease of access. and then find all the drivers for your keyboard online. AFTER finding them online, then reinstall them.
if this doesnt work i would back up only my files and do a fresh install of windows.
Please search google for hp keyboard problems because there are MANY of them. recently i just had problems with my hp laptop keyboard.
BTW i sent in my laptop to hp and they just changed the keyboard no questions asked so if all else fails or if you dont want to reinstall windows or the drivers just send it to HP.
SOURCE: HP G61 NOTEBOOK PC BIOS
It would seem that your BIOS has become corrupted somehow. First try entering your BIOS setup. I believe for HP computers when you press power tap the F10 key until it opens. There you can try to reset them in some fashion and save. Try rebooting. If that fails then remove the battery and repeatedly press the power button for about 10 seconds.. (make sure it is also unplugged, this is to discharge the power from the system) then replace the battery and try booting again. Otherwise it would seem that you might have tried to load the wrong BIOS into your laptop. Check with HP then if you are still covered or not. :/
SOURCE: Dell Vostro 1510 laptop.NUM lock
Go to dell site and check what LED flashing means.This points to the problem.good luck
