I set a code in the master lock speed dial 1500id, and it will not open. I cannot reset the code and do not know how to get this open. I have read the other suggestions and nothing has worked yet. Anyone have any tips.
Posted by marpeck277 on
yishai02
Try 2 options:
1. just squeeze the shackle twice and pull it out. This is in case you forgot to enter new combination.
2, Make the 2 combination together, the old and the new as one sequence. This in case you forgot to squeeze the shackle before enter new combination
Ity
Posted on Sep 17, 2011
How do I set up a Master Lock Key Safe with a new code
Open the box, with the existing combo, push the reset lever to the left and down, dial in your new combo, push the reset lever up and right to set.
Oct 04, 2014 | Master LOCK 5401D Combination Key Safe...
I lost the combination to my speed dial master lock and it is in the locked position. How do I open it and create a new code?
It's not easy to fix this problem, because these locks do not shim open and it's not obvious how a person could figure out the old combo. I was able to loosen and remove the security screws, disassemble mine and repair it. They are very tricky to reassemble and it took me hours to find the spring that was out of position. The root problem was the lock did not clear when the shackle was pushed in. Until I figured that out, it would take up to 30 tries to get it open. The security screws are Metric - so you can replace them with regular screws until you get it working. If you do open the case, there are a lot of small parts inside, including a bunch of springs.
Aug 18, 2014 | Master 1500ID Combination Padlock
My master 1500id lock won't move the circle seems very stiff and it won't open. I need to get my stuff for class
Try lock lubricant. Spray it sown around the shackle on both sides, and around the dial. Push the shackle into the lock body to unload the mechanism, then try to turn the dial again - if your hasp has the shackle under tension, it may drag the mechanism and keep it from unlatching.
May 12, 2014 | Cars & Trucks
I followed the directions to set my new lock and it did not work. So I am locked out of my new master lock speed dial 1500iD.
It happened to so many people. As people use to try it on their own and the problem occurs. I think you did not read or follow the manual guide carefully. But now you must call the locksmith guy to fix it. If you live in San Francisco then you can call Locksmith in San Francisco, as they are professionals and can help you out better.
Oct 25, 2013 | Locks & Locksmithing
I do not know the passcode for my phone
Resetting Phone Settings
Resetting the device restores all of the factory defaults,including the ringer types and display settings.Onboard data such as Contacts, History, Scheduler,and Messaging are not affected.
  1. Press Home and touch Main > Settings > Reset> Reset Settings. (A disclaimer is displayed.)
  2. Read the disclaimer, write down the lock code, and touch Proceed.
  3. Enter the lock code provided on the disclaimer by using the onscreen dial pad.
  4. Touch Done to reset the device's settings.
Resetting Phone
Resetting the device restores all of the factory defaults,including the ringer types and display settings and deletes all content stored on the phone.
  1. Press Home and touch Main > Settings > Reset> Reset Phone. (A disclaimer is displayed.)
  4. Touch Done to restore all factory settings.
Warning!: While reset/restore operation under process, you are advised not to remove your battery until the operation is completed and cellphone restarts otherwise phone damage may occur.*Disclaimer:Performing a master clear/master reset/hard reset will erase all your data (photos,videos,contacts etc) completely and reset all the settings to Factory default. The information contained in this website is for general information purposes only.In no event will resetcellphone.com be liable for any loss or damage including without limitation, indirect or consequential loss or damage. For complete disclaimer notice please visit Disclaimer. The brand names are the registered trademark of respective manufacturers.
Sep 06, 2012 | Samsung SPH-M800 Cell Phone
My friends were messing around with my 1500ID lock and changed the combination, then closed it. How can I reset it and change the combination?
Make your dumb friends find the code or buy you a new lock.
there is not trick to it... it'll have to be done by trial and error...
Sorry for your troubles.
Aug 31, 2010 | Master Lock 5400d: Portable Select Access...
990 people viewed this question
Marvin
Marvin
