Question about Kodak EasyShare C330 Digital Camera
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
Posted on May 08, 2017
SOURCE: GREEN LIGHT TURNS TO RED & CAMERA WON'T WORK
send it back and purchase a different camera
Posted on Jun 29, 2008
SOURCE: battery problems
The camera is probably defective. Warranty?!?
Unless you have put the batteries in wrong or not used fresh ones!
Posted on Aug 14, 2008
SOURCE: kodak z812 is problem
I had the same issue with my same brand/model camera for months. I used it maybe twice and then it decided not to turn on, no matter what I did. I finally got in touch with Kodak (the first time they told me to try different batteries, which of course did not help). I spoke with someone who figured out that I had a faulty memory card. When I removed my memory card, I was able to turn my camera on. I had to reset my date, but once I did that (still keeping the memory card out) I was able to take pictures just fine. Give that a try and see if it helps!
Another word of advice, if turns out to be your memory card, you'll need to purchase a new one. Kodak, of course, provides troubleshooting for their brand memory cards as well. Just an FYI.
Hope this helps!
Posted on May 20, 2009
SOURCE: Kodak EasyShare Z760 won't charge.
The problem might be that the battery has developed memory and won't charge further. My first battery used to do that, but then I read that you shouldn't leave the camera on the dock all the time nor keep the battery fully charged all the time because of the problem of developing memory. You might try running the battery completely down by taking pictures until it shuts down. Sometimes when my battery is low the dock won't charge (but goes straight to the red light), but when I run it completely down when I put it on the dock it charges properly. I hope this information helps. :-)
Posted on May 27, 2009
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
Posted on Jun 06, 2010
