HELLO IDEAL58ST,
While printing from the USB Port sometimes slow printout/data transfer will result in slow printing of print jobs.
SOLUTION:
Solution
After the printer is installed on the USB
Port, check the description under the Ports Tab what is selected.
Please refer to the figure below :
Using the USB/ Virtual Printer Port and DOT4/ HP Laserjet 2420, under the Port/Description
Tab printer speed will be as per the standard. Whereas using the DOT4/ Generic IEEE 1284 under Port/Description
Tab, Printer speed will be very slow.
If DOT4/ Generic IEEE 1284 is selected by
default, then you have to uninstall the USB driver from the Device
manager and plug in the USB cable again. Then it will detect the printer
and USB port with respect to the printer model.
THANKS.
