Question about Frigidaire GLER331A Electric Dryer
I have a Frigidaire FAFS4473LW Steam Washer- 3 prong. I moved into a new place with a 4 prong. Do I need a 4 prong cord, or can I change the 4 prong adapter on the wall?
Posted by nancy_huerta on
Curtis Sewell
  • Frigidaire Master
  • 7,482 Answers
Hi nancy huerta...
You can change the cord or the receptical...
It will be easier to change the cord...
Purchase a four prong plug cord that will fit into your receptical, then wire your dryer for 4 wire instead of three wire use.
To see a picture and explanation of how to wire your dryer for a 4 wire plug go to the following webpage.
Please take time to rate me
http://www.selfhelpandmore.com/switch-outlet/dryer-circuit-wiring-and-hookup.php
Posted on Sep 06, 2011
I have a three prong plug washer/dryer but a 4 prong outlet need an adapter
YOU DONT ADAPT IT, U REPLACE THE RECEPTACLE OR USE THE CORRECT PRONG CORD. THE CORDS ARE NOT THAT EXPENSIVE FROM 20 TO 30 BUCKS AND EVEN CHEAPER ON LINE. IF U HAVE A NEWER HOME IT IS MANDATED BY LAW THAT YOU USE 4 PRONG CORD NOT 3 PRONG UNLESS THE HOME CAME WITH A 3 PRONG OUTLET.
I have a dryer that has a 4 prong plug in i moved the place has a 3 prong plug in change the cord to a 3 or find adapter it is a frigidaire fde546res1
get a 3 prong cord,when you change it out do one wire at a time and you can't go wrong,you should see a white wire in the middle,a red wire on one side and a black on the other,the only difference is the 4 prong has a ground wire on it and the 3 doesn't and the way it plugs into the outlet.just follow the color of the wires
Moved and the new place has a 4 prong outlet. i need the wiring diagram to switch from 3 prong to 4 prong power cord
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will help you with changing your dryer plug.
Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2010 • Dryers
1helpful
I just moved and have a standard 3 prong outlet in my laundry room, the dryer has a 4 prong cord- what kind of replacement cord do I need to buy that will make the electricity of both the dryer and the...
<span style="FONT-FAMILY: 'Trebuchet MS'; FONT-SIZE: 10pt; mso-ansi-language: EN; mso-fareast-font-family: 'Times New Roman'; mso-bidi-font-family: 'Times New Roman'; mso-fareast-language: EN-US; mso-bidi-language: AR-SA" lang="EN">Here is a tip that will help you with changing your dryer plug.<br /><br />Dryer Cord and Wiring Dryer 3 Wire or 4 Wire<br /><a href="http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire" target="_blank">http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire</a><br /><br />heatman101 <br style="mso-special-character: line-break" clear="all" /></span>
Is there a adapter that is made for this product,my wall socket in the laundry room is made for a 4 prong cord, but the machine is a three prong Frigidaire FEX831CS Top Load... stakable
Sorry there is no adapter for the plug. You need to change the cord from the dryer or change the plug in wall. You can get a parts at homedepot.
2answers
Frigidaire GLEQ2152ES Dryer Won't Power UP
IF you find that you have only a 3 wire feed for this dryer (and the reason for the 3 prong receptacle)...then you can not properly install a 4 prong dryer cord to it. You now have 2 choices....either rewire (assuming that it is a 3 wire supply) the entire run from the dryer breaker to the outlet location with 4 wire (typically a run of 8/3 with ground having a black, red, white and bare ground)and install a 4 prong dryer receptacle to match the configuration of the new dryers cord.....OR - you can remove the 4 wire cord and replace it with a 3 wire cord....re-using the ground strap - IF it is still in place.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
3helpful
2answers
Change fr 3 prongs to 4
They wire in the same except the green wire will go to a ground screw which should be right in the same area with a green color to it. If no ground screw, hook the green together with the white (center) wire. Hope this helps!
6helpful
2answers
Changing cord from 3 prong to 4 prong on frigidaire dryer
The following link explains how to convert your appliance from a 3-prong to a 4-prong power cord:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
I hope this helps you. Let me know if you still have questions.
Kenmore stackable unit
Yes, you can use any safety 4-prong as long as it is a dryer cord rated at 220V.
Frigidaire GLER331A Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
