I have oiled & cleaned machine like the book. sews along & all of a sudden skipped stitches, have checked & changed needles cleand dog feeds. Chanked the top tension. Still skipped stitches.
If your Janome Mystyle 22 sewing machine is skipping stitches specifically when using the buttonhole function, there could be a few possible causes for this issue. Here are some troubleshooting steps you can try:
1. Needle: You mentioned that you have already changed the needle, but it's worth double-checking that you are using the correct needle type and size for the fabric you are working with. Ensure that the needle is inserted correctly and tightened securely.
2. Thread tension: Improper thread tension can cause skipped stitches. Make sure the upper thread and bobbin thread are properly threaded and that the tension settings are adjusted correctly for the fabric you are using. You may need to experiment with different tension settings to achieve the best results.
3. Buttonhole foot: Check that the buttonhole foot is attached securely and positioned correctly. Ensure that it is clean and free from any lint or debris that may be affecting its performance.
4. Feed dogs: The feed dogs underneath the fabric may not be gripping the fabric properly, especially when working with lighter fabrics. Ensure that the feed dogs are clean and free from any obstructions. You can try using a fabric stabilizer or placing tissue paper under the fabric to provide more traction for the feed dogs.
5. Lubrication: While you mentioned that the machine was recently serviced, it's possible that the buttonhole mechanism could benefit from some additional lubrication. Consult the user manual or contact Janome's customer support to inquire about lubrication points and recommended lubricants for your specific model.
6. Stitch length and speed: Adjusting the stitch length and sewing speed can sometimes help improve buttonhole stitching. Experiment with different stitch length settings to see if it makes a difference in stitch quality.
If you have tried all these steps and the issue persists, it may be best to consult a professional technician or reach out to Janome's customer support for further assistance. They will be able to provide specific guidance and recommendations based on your sewing machine model.
The U shaped clamp usually hooks "around" the needle screw. Yes, usually the walking foot may need oil (just a tiny bit) where the parts move against each other.
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
5. If the above suggestions don't help then the machine needs to be checked
For a timing problem.
try these suggestions and see if they help Skipped stitches
the needle bar is not hollow, Skipped stitches
