Sony SRS-A37 Computer Speakers Logo
Anonymous Posted on Sep 06, 2011
How many volts is the power adapter - Sony SRS-A37 Computer Speakers
Robert Lissor
Level 2:
Sergeant:
  • Expert 263 Answers
  • Posted on Sep 06, 2011
Robert Lissor
Expert
Level 2:
Sergeant:
Answers
263
Questions
0
Helped
49267
Points
768
The speakers use a 10 Watt power supply
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15003852
Points
237762
Hello
Your Sony active computer system SRS-A37 needs a DC adapter of 9Volts. I hereby give you its specificatins.
Power requirement
DC 9 V, 900 mA; or six R6 (size AA) batteries
(left speaker only)
Battery life (at 5 mW + 5 mW
output)
Approx. 10 hours with Sony
batteries R6,
Approx. 24 hours with Sony
alkaline batteries LR6
Use a DC adapter which can provide (VDC 2Amps) output. you can use any DC adapter of this specifications. OK.
  • The Knight
    The Knight Sep 07, 2011
    The adapater needs [9VDC - 2Amps] capacity.
I would like to charge my 930 T on 120 volt A C adapter
Complete Guide to Using the Correct Charger or Power ...
www.groovypost.com/.../choose-right-power-adapter-charger-phone-lap...
Oct 18, 2015 - Read this guide on finding the right charger or power adapter. ... As part of that process, I took all my power supplies and adapters and threw them into a box. ...from a 120 V AC outlet in your home) and convert it to a specific DC output. ... Voltage is measured in volts (V) and current is measured in amps (A).
Is there a way to charge my 930 T on a wall socket AC adapter
www.fixya.com/.../t26037021-way_charge_930_t_wall_socket_ac_adap...
24 mins ago - is there a way to charge my 930 T on a wall socket AC adapter - PC Laptops ... I would like to charge my 930 T on 120 volt A C adapter. Jan 03 ...
AC versus DC charging - what is the difference? ' Plug In ...
www.pluginamerica.org > Blogs > Drivers Seat
Plug In AmericaOct 13, 2013 - It is simply a USB cable, which allows my tablet to charge from a DC USB ... When you plug in to AC power - whether you plug in to a 120V or .... 120vphone chargers and plugging in to 74 volts DC and charging their phones.
1helpful
How can i hook up a car stereo in the garage without using a car battery, and get the same juice as far as wattage and power???
Wire a 12 volt AC adapter to it. Connect the power to the positive wire, & the ground to the negative wire. If it's a low power unit a 1 amp adapter will work. If it's a high powered unit you might need a 12 volt 5-10 amp adapter designed for monitors, TVs, monitors, & some laptops. Beware some laptop AC adapters can be 16-36 volts. Make sure you use a 12 volt one, & know which wire is positive, or you'll burn it out.
Can i use any charger on s505
The Toshiba Satellite 5205 series of Notebook PC, and the S505 series model; uses an AC adapter (Charger) that produces 15 Volts DC.
http://www.sparepartswarehouse.com/Toshiba,Satellite,5205,PS520U-31P1RV,Laptop,AC-Adapters.aspx
You will see AC adapters sold that show 15 to 24 Volts. (DC)
http://www.duracelldirect.com/toshiba_satellite-5205-s505_ac-adapters_laptop_ac-b20h.aspx
This is because the AC adapter (Charger) has PFC.
Power Factor Correction,
http://www.hardwaresecrets.com/article/Everything-You-Need-to-Know-About-Power-Supplies/181/2
Also I see it is just a two pin AC adapter plug, to laptop.
Center hole is Positive, outer metal cylindrical metal shell is Negative.
Go for 75 Watts or higher though, and not a 65 Watt model.
[ On the case of the AC adapter;
Input: 100 ~ 240 VAC 50-60Hz
Means it can use from 100 to 240 Volts AC, and either 50 or 60 Hertz.
Output: 15VDC 6A
Means 15 Volts DC at 6 Amp's. (Amperes)
Watch the outside dimension of the cylindrical part, and the center hole dimension. Outside cylinder may be correct, but center hole may be too small. Or vice-versa.
Regards,
joecoolvette
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
1helpful
T23 2647 Think pad AC power adapter lost
No. You must use a power supply that is 16 volts or that is specified to be used with the laptop.
You can find the information about the power consumption (volts and amperage) underneath the laptop. If it says 16 volts then you MUST use a 16 volt power supply.
If you try using a 19 volt power supply you run the risk of damaging the motherboard or blowing the motherboard completely.
Regards.
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Laptop won't power up without battery, needs 135W adapter
The ASUS power adapter is below spec and it may damage the adapter because the HP is drawing 45 W more power than it can deliver and will cause it to overheat.
The 17" HP requires 18.5 or 19 volts depending upon the model of the HP laptop (check the power requirements on the label on the bottom of the laptop). If the ASUS adapter doesn't deliver this voltage, it most likely won't power up the HP laptop.
Use the power supply/adapter from the other 15" HP. If this HP's adapter has a voltage output of 19 volts and the 17" laptop requires 18.5 volts, don't worry a voltage difference of 0.5 volts, the only problem is whether the power plug will fit into the power socket of the 17" HP laptop.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
