Question about Kenmore Top Freezer Refrigerator
Have a kenmore refrigerator freezer works but not refrigerator
Posted by Jeff Struzyk on
Anonymous
    Novelist:
  • 78 Answers
You mean "How to Fix a Kenmore Refrigerator That Is Not Cold But the Freezer Is Good?"
Well this what i say,
Kenmore combination refrigerator and freezers combine the short- and long-term food storage options in a single unit. There are some occasions when the refrigerator compartment might appear to be malfunctioning while the freezer box stays cool. Ruling out these occasions ensures you have done everything you can to correct the problem before calling for a technician if necessary.
1.Verify that the temperature controls for the refrigerator compartment are properly configured. Tap the "^" or "v" buttons beside the refrigerator's LCD temperature display until "38," the ideal temperature, appears. The compartment could have been set too warm. Allow 24 hours for the the appliance to reach 38 degrees Fahrenheit.
2 Check that the refrigerator compartment door closes completely, objects inside the appliance could be holding the door ajar. When cool air is allowed to escape, the internal temperature rises. Cracked, holed or corroded door seals may also raise the refrigerator temperature.
3 Change how you use the refrigerator compartment; storing hot or warm food strains the appliance and causes a rise in internal temperatures. Do not prop open the door or leave it ajar for more than a few seconds at a time for the reasons outlined in Step 2.
4 Contact Kenmore if the refrigerator compartment remains too warm for your food. There may be a problem with the motor or any one of the other parts that regulate the temperature
If this was helpfu.l please let me know.
Thanks for using FixYa
Posted on Sep 06, 2011
My Kenmore Refrigerator - freezer works - refrigerator on bottom does not
CHECK THE AIR CONTROL YOUR NOT GETTING AIR FROM THE FREEZER
Jan 27, 2013 | Kenmore Refrigerators
My kenmore fridge is not working, the freezer works fine but the bottom will not cool. the fan is working but not blowing out air in the bottom
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 30, 2011 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Refrigerator 75509 double door top, bottom freezer. Freezer is working, but the refrigerator is not cooling
heatman101
Apr 29, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
Freezer works, upper section not cooling on Kenmore bottom freezer.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
The cooling is not working in the refrigerator portion of my Kenmore Bottom Freezer Refrigerator. The freezer works fine. Any idea why that is? Thanks.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Aug 31, 2010 | Kenmore Refrigerators
My kenmore coldspot 72852101 refrigerator not working but freezer seems to be working
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Jul 21, 2010 | Kenmore 64802 Top Freezer Refrigerator
My kenmore top freezer doesnt work my
the refrigerator may need some refrigerant, it might have a leak.
Mar 06, 2010 | Kenmore 64722 Top Freezer Refrigerator
Kenmore refrigerator 25364150400 fridge won't get
check your evaporator coil in freezer it is froze up ,need to check to make sure defrost timer is working. Also check drain line.
Apr 10, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
gbob59
Dale Copeland
Dale Copeland
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
