Hello, this usually indicates a clogged condensate line or cracked condensate pan. Try using a wet/dry by attaching one end of it to the otlet of the comdensate line, the suction pressure should dislodge the clog. If the line appears clean the the pan is cracked and will require a technician to come out and fix it.
The water is the humidity captured by the air conditioner. It should drain via a drain line, or directly out of the bottom of a window unit to the outside. If it leaks from the unit itself, the drain line is clogged.
I am not clear on exactly where the condensate is leaking from. I will assume it is leaking from the air handler. If so, the primary condensate drain line is clogged up between the unit and the sump or pump it drains into or the condensate tray in the air handler has clogged up with debris.
To remedy the problem the condensate line must be cleaned out and/or the condensate tray.
Hope this helps.
