Canon PIXMA  MP160 All-In-One InkJet Printer Logo
Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i change an ink cartrige in a canon 160 printe
Anonymous
Level 2:
Novelist:
  • Expert 139 Answers
  • Posted on Sep 06, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
139
Questions
0
Helped
35072
Points
452
The Canon Pixma inkjet printer is an all-in-one printer, scanner and copier capable of printing high-resolution photos. One handy feature is a slot for a memory card so you print photographs directly from your camera. It can also print completely without any border for full-sheet photos. Printing photos and other high-fidelity documents uses up ink more quickly, and you will probably need to replace at least one of your cartridges every three to six months, a process that should take you about three to five minutes.
1.urn on the printer and check the LCD screen for an indication of which ink cartridges are low. Note that recycled ink cartridges sometimes read "Ink low" even when they still have ink, so print a test page if you're not sure.
2.Expose the ink tray by lifting the entire LCD control panel, which is attached to the underside of the copier tray.
3.Pull out the used ink cartridge by pulling straight up from the print head, and dispose of them safely and carefully by putting them in a sealed bag.
4.Remove gently any packaging from the new ink, after giving it a few shakes. Pull off the protective tab on the cartridge, insert the new cartridge into the print head and push down until you feel a click. Close the printer lid and let the printer reset the ink tray.
5.Print a test page to make sure the new ink works. If it doesn't, you may have forgotten to remove the protective tab under the cartridge.
Canon pixma ip1000 black ink stop printing suddenly
Based on your explanation I will try to help.
Your ink tank had run out. You can refill it through the bottom of the tank or just simply replace your ink tank.
2helpful
Refilled black ink cartrige and i can't get it to print at all. done more deep cleans than i want to remember, still will not print. done nozzle clean also. i have refilled this cartrige several times...
You may need a newer cartridge
See if the printhead has any abnomal markings.
You can compare it with the color printhead.
If the printhead is good, see if the ink is flowing through the printhead.
Fill the ink cartridge to maximum
Squeeze the sides of the ink cartridge, ink should flow out.
If ink is flowing out, remove any excessive ink with a paper towel.
Install ink cartridges, do NOT do any cleaning cycle.
Since your black cartridge is full, cleaning may cause it not to print.
Do some black copy operations.
5helpful
I have Canon multifunction MX310 I was using
press the Stop/Reset button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.Canon do not like you to use refills and generic carts so the function for detecting the remaining ink level will be disabled
Canon MP 610 printer. Cartridges half full when forced to replace
well printers calculate ink, with printing jobs. If you exchange cartriges in the middle of these ( ex:you exchange cartriges about after 100 print jobs and the cartriges is 500 top) the printer dont know excatly the ink level, so gives these error on calculation, not exact ink level. so you need to take out and place again to reset cartridge counter.
Will not print in black.
1st clean heads, on printers menu, then check if you have instaled non canon ink cartridges, you maybe burn out ink printheads. ONLY USE ORIGINAL INK CARTRIGES ALWAYS.this a normal failure on NON CANON INK SPARES.
Ink smears
You need to clean it inside, use isopropylalcohol witch is good for cleaning ink
4answers
CANON FAX JX200
remove the cartridge and see if it goes away, if does then you probably have a defective cartridge are are not inserting it correctly.
Thank You,
Mikey
Ink cartrige
Purch. a new cart see if that works.
old marine
old marine
ZJ Limited
ZJ Limited
