Question about TruTech PVS31170S1W 17 in. LCD Television
A black rectangle has appeared on the screen, blocking out most of the picture. How do I fix it? thanks
Posted by lbdbarr on
Chi Chu
  • TruTech Master
  • 8,457 Answers
Ur tv still have the funsctions ON like Close Captioning.U have the tv original remote wright?Yes?Tries the remote button like CC on ur tv remote pushes it a couples make sure like CC1,2.3..turn all off.Tries go into the tv Menu tries looking for Closed Captioning functions turn CC1,2,3...turn it all off and Text1,2,3...turn it all off too.These two functions off.Tv will stop this big black box poping up on the tv screen.
Posted on Sep 06, 2011
I get a black rectangle in the middle of the screen. I can click any button (mute, view mode, cc) and the black rectangle will go away and whole picture will appear, for a couple of seconds and then the...
I do know that on Zenith CRT televisions of the 1990's this will happen and all I did to fix it is to go to the menu and turn the text feature off. This may be true with your Sharp as well.
1helpful
2answers
Vizio VX37L HDTV black rectangle in lower right corner
Turn off the Picture in Picture (PIP) option using the remote control. I had this problem and it worked for me!
Why did a rectangle box appear on the screen
PIP is on (Picture in Picture) either from your cable box or the TV. Check your remotes for "PIP". If you still have an issue, post a comment and I can help you more
2helpful
2answers
A black rectangle is displayed on the screen
the black rectangle appears as soon as the channel indicator goes off. someone has turned on the closed captioning in the menu of the set. it is in the "text" mode. go into the menu and turn off the closed caption feature.
1helpful
Blackout area on screen
Make sure the TEXT and CAPTION options are turned off.
I am not sure about the Sonny's, but on my Toshiba a black box appears when I inadvertently leave one of the close captioning (CC) on for text or captions on (such as CC1, CC2, etc.).
Black Rectangle Box appears shortly after turning on TV
That is the PIP (picture in picture) setting, on the TV's remote control. locate the button marked PIP and press the button, it should clear the little box.
2helpful
Black rectangle on bottom half of screen
captioning on turn off with remote.
Using rooftop antenna through converter bos to RCA TV
Turn off the text box function of the closed caption decoder on the tv.
Black square on one channel
that's a picture inside a picture option, and it sounds like the inside picture is set for a blank channel...just go to the menu, and shut off the picture in a picture option..should do the trick..
and keep the kids away from the machine
2helpful
2answers
Black rectangle on screen
Try pressing the "View" button on the remote control a couple times -- it sounds like you have the picture-in-picture mode turned on but with nothing showing on the second input.
TruTech PVS31170S1W 17 in. LCD Television Logo
Top TruTech Televison & Video Experts
 Francisco Mauricio...
Joaquim Martins
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
