Cell Phones Logo
Question about Cell Phones
How to block my phone - Cell Phones
Posted by lance_rbc28 on
Anonymous
  • Cell Phones Master
  • 32,281 Answers
Ifyour mobile phoneis lost or stolen you can inform your cell phone provider with your IMEInumber. Your cell phone provider can then put the serial number on a shareddatabase. This list stops this particular phone from registering on any networkand will be useless for anyone even if the mobile phone's SIM cardis changed. I suggest you contact your cell phone providerASAP. To lock/block your cell phone from further use, please click on this link:- http://www.fixya.com/support/r5057854-lost_or_stolen_cell_phone
Posted on Sep 06, 2011
How to block an incoming call on landline vtech wireless phone
If you subscribe to Caller ID service, your phone can block calls from up to 20 specific phone numbers. This is called the BLOCK LIST. It can also block any call that does not provide a phone number with the Caller ID. This is called CALLS WITHOUT NUMBERS. In either case, the caller will hear a busy signal, and the call will be disconnected.
To add phone numbers to the BLOCK LIST:
When the phone is idle, press MENU/SELECT.
Press VOLUME? until you see Call Block, then press MENU/SELECT.
Block list is displayed. Press MENU/SELECT.
Press VOLUME? until you see Add new entry, then press MENU/SELECT.
Enter the complete phone number of the party you wish to block, then press MENU/SELECT.
Enter the name of the party, then press MENU/SELECT.
To activate the CALLS WITHOUT NUMBERS feature:
Press VOLUME? until you see Calls w/o num, then press MENU/SELECT.
Press VOLUME? until you see Block, then press MENU/SELECT. All calls without a phone number will be blocked.
2answers
How can I block a caller
By using truecaller you can block a caller or go to phone setting to block calls, open the Phone app, select Call History, tap the number, then select Block Contact or Block Caller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.
Aug 08, 2018 • Cell Phones
I have a Doro cell phone and wondered if I could block phone calls.
https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-on-doro-phoneeasy-612/
How to block phone number on Doro PhoneEasy 612 Phone Info
Quoting from link: "Start by going to "Contacts" and tap on the contact you want to block. Then, press the menu key at the top left of your Doro PhoneEasy 612. You will see a menu where you will select "Block Number" or "Add to Auto Reject List". The title may vary depending on the model you own."
How to block numbers
To block calls, open the Phone app, select Call History, tap the number, then select Block Contact or BlockCaller. To block calls, open the Phone app, select Menu > Settings > Call Reject > Reject Calls From and add numbers. To block calls for numbers that have called you, go to the Phone app and open the Log.26 Sep 2016
How to Block a Number on Any Phone ' PCMag.com..
or go to this link for other phones. How to block numbers Google Search
Oct 28, 2017 • Cell Phones
2answers
Blocking nuisance mobile phone number
Can no be done. Iphone doesn't have a 'black list' for phone numbers
3helpful
3answers
No manual and am receiving unwanted calls at night just became threatening how do i block them
Using Call Block
If you subscribe to Caller ID, you can save phone numbers to the call block list. When a call comes in, the phone compares the received phone number to the numbers on the call block list. If the phone number is on the list, the phone replaces the caller's name with Call Blocked and disconnects the call. (The caller hears a reject tone.)
The call block list holds 20 entries, and all stations share the same list. You can add entries through the Call Blocking menu, by selecting Add Call Block in the CID menu, or by blocking incoming calls. (Only one station can edit the call block list at a time.)
Blocking incoming calls
  1. When the phone rings, wait until the display shows the Caller ID information (usually after the second ring).
  2. If you want to block the call and add this number to the call block list, press Block.
  3. When the phone asks you to confirm, press Menu/select or Block. Blocking an incoming call from an "Unknown" or "Private" number is the same as selecting Unknown Number or Private Number from the Call Blocking menu.
Call Blocking menu options
  1. With the phone in standby, open the menu and select Call Blocking.
  2. Choose one of these options:
  • Create New(Handset only) - Add an entry to your call block list. The phone will prompt you to enter a name & phone number.
  • Private Number(Handset only) - Block all calls from numbers reported by CID as "Private." (This does not count as one of the 20 entries.)
  • Unknown Number(Handset only) - Block all calls from numbers reported by CID as "Unknown". (This does not count as one of the 20 entries.)
Call block entry options
  1. With the phone in standby, open the call block list and find the entry you want.
  2. Press Menu/select to open the individual entry menu. Choose one of these options:
  • Edit(Handset only) - Edit this entry. The phone will prompt you to edit the name & phone number.
  • Delete - Erase this entry from the list & allow calls from this number.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1helpful
Pin blocked
You need to get a PUK, PUKs, or personal unblocking keys, are used to unblock a mobile phone which becomes blocked. Mobile phones may become blocked when a PIN (personal identification number) is entered incorrectly on three consecutive occasions. In some instances, the phone may become blocked, which requires a PUK to unblock it, and in other instances, the SIM (Subscriber Identity Module) card itself becomes blocked and again will require a PUK to unblock it. Mobile phones are also blocked when they are reported stolen and if there is an outstanding payment on the account. It is important to differentiate between unblocking phones (using a PUK) and unlocking mobile phones (using another type of code). More information on unlocking phones will be available here in the very near future. NOTE: It is a criminal offence for anyone to attempt to unblock a mobile phone, other than the network provider who put the block on the phone. If your phone has become blocked by mistake, for example you have entered the PIN incorrectly on three consecutive occasions, then you need to contact the mobile phone network operator with your details. To explain a little more, specific to your mobile phone network, use the links above to navigate your way to the specific PUK details for your mobile phone network operator.
5helpful
4answers
Blocking a phone number
if you want to block your own number dial *67 before you dial... to block someone else try dialing
To activate Call Block or add a telephone number to the rejection list, dial *60. If you dont know the number to be blocked, dial *60 immediately after hanging up from the call. To turn off Call Block, dial *80. Call Block cannot block calls from some cellular phones, pay phones or business lines. It also cannot block most long distance numbers.
hope this helps...please rate...thanks
3helpful
4answers
Blocking numbers on cell phone
Unfortunately, Sprint does not have the ability to block single numbers from calling you. We can either block all incoming calls, all outgoing calls, or both, but not particular numbers.
Top Cell Phones Experts
Marvin
Marvin
ADMIN Andrew
ADMIN Andrew
Are you a Cell Phone Expert? Answer questions, earn points and help others
