Acer AL1916W 19" LCD Monitor Logo
Posted on Sep 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i'm playing games in my pc, they run fine.. but after a while like 5min the monitor goes black with that rectangular box saying "Input not supported" i have an acer AL1916W and an AMD Radeon Hd 4850.. so please i wanna play and i can't!!!
Anonymous
Level 2:
New Friend:
  • Expert 66 Answers
  • Posted on Sep 06, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
66
Questions
0
Helped
12486
Points
225
Update your video car drivers and then look for the specific drivers of your monitor, it happened to me once using windows 7 i just installed the monitor's driver from the manufacturers website. go to acer website and support download page and search for your model, donwload and install and hope that solves your problem.
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Game has error, says to consult Wii operations manual
It's most likely the disc that is causing trouble. If all of your other games work, it the game you bought. I had the same problem with MySims Party, I went to the store where I bought it, they gave me a new disc, which worked fine.
Hi I'm using a VisionTek Radeon 9250 128 MB PCI video card and every time I try to run any PC game I have, my monitor will freeze and then the screen will go black. Sometimes, this will result in my...
Hi caeggleston,
"every time I try to run any PC game I have" Running the games before, do you encounter the same problem you posted. If not there's a problem, have you read the system requirements of the game your playing before installing, unless its a mini game like book of worm etc. but most game now a days requires a decent video card considering you're using a AGP video card. try to run 3D Mark 2003, 3D Mark 2006 or FurMark (for stability) if there's no problem with the card it should stand the stress test or just a simple test. If you see garbled image during testing, your video card have problems consider replacing them.
Hopefully this information helps.
Thank you for using FixYa.
When I boot up my PC my Acer monitor says "auto config please wait" then goes black. It works just fine through the boot up until it gets to the login screen. That's where it eventually goes...
Try power off then power on your PC press F8 choose highlight safemode press enter. if nothing happen no display on screen your CPU have problem contact service center for that CPU.
34helpful
10answers
WHEN I START PLAYING TOTAL OVERDOSE IN MY WINDOWS XP A BLACK SCREEN APPEARS AND SHOWS "OUT OF RANGE:" PLEASE PLEASE HELP ME
yes minamino kitagami is right,
goto start menu ,
select Run
type in "dxdiag"
DirectX Diagnostic Tool will run
then click at "More Help"
you will see there Override tab in last just click it
after that "Refresh appears"
set it from default to override rate "60"
now exit.
and play the game enjoy.
My screen just stopped working and I have a rectangular box floating around in a counterclockwise rotation that says " Check cable signal " Do you have any ideas? It was working fine up...
that means your monitor is working fine, just check your video connection on both ends of the monitor and PC.
maybe your PC has two video cards, try to plug in another video connector
2answers
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Lcd montior with tv box but no hdmi sound
in some cases certain manufacturers say in the instructions that when using s video with seperate audio, you cannot use the HDMI for the sound and sometimes visa versa, it's just the way the output is set up. Remove the other sound cable you are using for pc or tv and just use HDMI to confirm that the sound is re-enabled on the HDMI
Input Not Supported?
Try changing the resolution in the game. If that doesn't work change the resolution in 'Control Panel' under 'Display'
2helpful
Input not supported when trying to play a game
the game will need to be set to the same screen resolution as your monitor or the best that suits, beccause of it being widescreen, so look in the graphic or video settings in the game, or change the resolution of your monitor to suit the games highest setting. This is done by right clicking on your desktop, down to properties and then the settings tab in the next window and then move the slider at the screen resolution box.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
