KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher Logo
Question about KitchenAid 24 in. KUDI02FRSS Stainless Steel Built-in Dishwasher
I don't know which Kitchenaid I have but it is brand new, and I haven't used it yet. I opened it and pressed normal wash, and I see the blue light blinking on the lock setting. Anyway I shut the door and nothing will happen??? How do you get it to start??? I'm just thinking that if the dials are on the top of the door you might know what I am supposed to do.
Posted by lyndarobert on
glenn Meek
    Habit-Forming:
    New Friend:
  • 34 Answers
See if there is a start button on the right side of that control panel.
Posted on Sep 26, 2017
5 Related Answers
Anonymous
  • 1314 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Posted on Feb 12, 2008
Anonymous
  • 3 Answers
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Posted on Mar 25, 2008
Anonymous
  • 9 Answers
SOURCE: KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Posted on Aug 31, 2008
Tom Giardino
  • 7 Answers
SOURCE: KitchenAid Dishwasher Door Pops open during cycle
I have had the same problem since our KitchenAid was new. The only solution so far is to try bending the metal door latch down slightly. You will know when you have bent it too far as the door will no longer close. Just bend it back up slightly. I used to work in the appliance industry and got the service man to admit that the door latch has been an issue and there is no real fix. I have looked at the new KA dishwashers and they have since redesigned the door latch. I am going to see if the new latch can be retrofitted into my Kuds01FLSS6 dishwasher. I will post on here if indeed it works.
Good luck
Tom
Posted on Jan 14, 2009
Jeff Meyer
  • 423 Answers
SOURCE: Heating element circut malfunction In Dishwasher. Wash not workin
Great job walking through the possible causes! Hey, it is time to check the heating element itself. First visually, looking for brakes and then feeling for "bubbles" on the round element rod. Also see if it moves excessivly when you wiggle.
If no problem obvious, after you disconnect the dishwasher from power, use a multimeter to check for resistance (Ohms) If none, look for broken (heavy guage) wires and replace what's broken - probably the element itself.
If the element checks out good, suspect the thermistor then the controller/PCB.
Good Luck! Please report back what you find, OK?
Posted on Apr 11, 2009
1helpful
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
How to reset a Kenmore 668.1687582 dishwasher
Yes, depending on the model, and the buttons that your dishwasher has, try the following key sequences:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds.
On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
1helpful
Adjusting front (most powerful) burner on kitchenaid (Left front)
There is an air port near the adjustment knob. Open for a more blue flame and close for a yellow flame. If these haven't been moved before, you probably have a clogged jet at the burner. Just clean it out with a pin.
The doors of my technics deck RS TR575 don't open or close when I press open/close switch, it sound , but not responding. Please help me Thanks Manuel
It's a simple job for a repairer - if you can find one that will have anything to do with audio cassette technology anymore, sorry, but I'm finding that some won't.
Not knowing where you are I don't know which currency you use but if it helps, here in the UK I'd say don't spend more than £25 on this.
There are still new cassette decks made and lots of good used ones around.
I know Technics is a very good make but I was looking at superb condition Nakamichis the other week for £35 which are a far better brand.
I Haven't been able to open my SBCglobal.net email account in years and I would really like to fix the problem. I don't even know where to start. Help!
you have to sign up for new account.sometimes if you are not using it. they might blocked it like my account in yahoo mail i could no longer access it i don't open it for a year also.that's why i made another account if you sign for a new one you should open once a week or once a month just infrom your friends that you have a new account.
1helpful
I've recently bought a Hoover 800F New wave and I don't know how to open the door...can you help me please?
turn the wash temperature control knob anticlockwise until you come to the key symbol at the end of the blue zone; then turn the knob a little further and the door will swing open; a special safety device prevents thedoor from opening during the wash or at the end of the spin cycle; at the end of the spin wait up to two minutes before opening the door - the instructions from the user's manual. good luck!
Do you need to keep the door open when not being used. i know some models require that.
There's no special requirement that you need to keep the door open. But, If you keep it closed after your done washing, some water is usually left behind and if you don't wash for a few days it could make the first few loads have a certain musty odor. I always leave the door open for a few days to dry out the insides then close the door and I haven't noticed the musty smell. Good luck.
2answers
Top KitchenAid Dishwashers Experts
Mike
Marvin
Marvin
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
