SOURCE: Screen went blank
There is something you can try. Using a Torx 6 driver, remove the two screws located beneath the battery. Gently pry the plastic cover loose. There will be a flex cable connecting it to the other portion of the phone. Gently disconnect it. Using 99.5% isopropyl alcohol and a soft bristled brush clean the connectors on both the cable and the circuit board. Reseat the connector and reassemble the phone. If this does not work the flex cable or LCD may need to be replaced.
SOURCE: Black Screen
Hi, before sending it in or taking it to a Motorola repair station, try this. Open phone turn it over so camera is facing you with finger behind and thumb of your right hand sweeze the area between camera lens and the vol up down button to reseat the ribbon connector that is located in that area between the cases. This worked for me and it is worth trying.
SOURCE: Motorola RAzr V3 - screen went black but key pads lights up
replaced the flexcable on the phone to have it fix
SOURCE: Blank or White screen on new Motorola Krzr k1 cell phone
the white screen is because the 'flex' is broken. u need to change it. the 'flex' is a part that connects the upper part ( screen) and the lower part (keypad) of the cellphone. the flex is a common problem with flipflop phones. i dont know if u can get it in your country, but we have lots here. it costs around $14-15 including labor.
i was able to solve the white screen problem, but one of the 2 problems w this cell still exists. Whenever i close the flipflop, "memory card removed' appears, and it keeps blinking. Or when i charge my cell, this msg also appears. this also drains my batt. If i reinsert my memory card, it solves the problem, but whenver i charge my cell, it appears again. So its kind of a hassle to always open the back of the cell to reinsert the memory card, so what i do is , i never close the flipflop. Anyone has the same problem?
its the FLEX CABLE! need to change it..the cable that connects the LCD screen to the main motherboard
