On this type ice box the cold air for the freshfood section comes from the freezer via a fan motor. For all of it to work propah the freezer must not be crammed full. The air has to circulate or the fresh food section will suffer. So if you have it overloaded where the air cannot get below then Houston we indeed have a problem. If that is fine we want to next check to see if the fan is blowing up in the freezer section. No fan no cold air below. If that is fine we want to make sure the evap coils ain't froze ova by a faulty defrost heater or termination thermostat. If the defrost is all propah AND the fan is fine AND the coils behind the ice box are clean for optimum performance, then look for a clogged defrost drain. Sometimes the drain cloggs and the water pools between freezer and fresh food section. A slab of ice forms effectively blocking any cold air from gettin to the bottom. To cure that yall unplug it and let it all thaw out then clean the defrost drain. If ice is blocking the defrost drain then run a wire down into it from the heater to keep the drain open and party on!
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
